Buffalo DriveStation Media 1TB USB3.0
Quicklinx: D0L7WS00 Mfr#: HDV-SA1.0U3-EU
Form Factor: 3.5"
Capacity: 1TB
Interface: USB 3.0
£77.90 ex VAT
£93.48 inc VAT
Buffalo Technology's new HDV-SA series enables users to maintain extensive media libraries while freeing up TVs, TV recorders, and PCs to keep recording the programs and movies they love.
Buffalo's external Media Hard Drive is both beautiful and well-designed. From the outside the drive visually blends with surrounding devices and cables are placed out-of-the-way, and held there, to maximize the drive's convenience.
Inside the HDV-SA series has a special fan-less and floating structure, and vibration-dampening rubber, to assure the quietest possible operation.
Buffalo's Media Hard drive is Panasonic-approved and includes optimized firmware that helps ensure smooth streaming playback with special AV commands and superior error handling for Panasonic devices.
Buffalo's HDV-SA series comes in 1, 2, or 3TB capacities with factory-confirmed hard drives tested for both high reliability and durability.
BUFFALO DriveStation HDV-SA Series Media - hard drive - 1 TB - USB 3.0
Hard drive - external (desktop) - vibration dampening, ECO, fanless design
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Vibration dampening, ECO, fanless design
Power Source
Included AC adapter
12.3 cm x 20.7 cm x 4.05 cm
900 g
1 TB
USB 3.0
Internal Drive Interface
SATA 6 Gb/s
12.3 cm
20.7 cm
4.05 cm
900 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
Included AC adapter
Power adapter
Power Consumption
18 Watt (active)
Microsoft Windows 7 (32/64 bits), Windows 8, Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
5 °C
35 °C
20 - 80% (non-condensing)
Form Factor: 3.5"
Capacity: 1TB
Interface: USB 3.0
Brand: Buffalo
Price Range Ex VAT: 50 - 100
