Product
Buffalo Business Switch L2 10Gbit, 5Gbit, 2.5Gbit 8 Port
Quicklinx: D0LQWS00 Mfr#: BS-MP2008-EU
Type: 10 Gigabit Ethernet
Ports: 8
Hurry, only 1 left in stock!
£355.32 ex VAT
£426.38 inc VAT
Buffalo's BS-MP series of 10GbE switches offers an easy, cost-effective and energy-efficient way to extend your business network at blazing speeds. Plug and play installation requires no additional software or configuration; simply plug your network-ready devices into one of the available Ethernet ports. Each AUTO-MDIX port automatically detects and configures the correct connection while optional jumbo frame support and full duplex operation provide maximum performance. This switch is a perfect complement to the TeraStation 5010 line of NAS devices which has up to 2 native 10GbE ports and is compatible to 2.5, 5 and 10 GbE. Along with 802.3az Green Ethernet technology, the BS-MP series includes intelligent Power Control, an energy conservation feature that monitors the activity status of each port to reduce the total power consumed. Its durable, metal chassis has holes and comes with rack mounting accessories for easy wall- /rack-mounting or rubber feet for placement on a desktop.
BUFFALO BS-MP20 Series BS-MP2008 - switch - 8 ports - rack-mountable
Switch - 8 ports
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
8 x 100/1000/10000
Performance
Latency: 10 µs , Backplane speed: 160 Gbps , Data transfer rate: 80 Gbps
Buffer capacity (MB): 2
MAC Address Table Size
16000 entries
Jumbo Frame Support
9216 bytes
VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, packet filtering, store and forward, MAC address filtering, full duplex mode, Quality of Service (QoS), Energy Efficient Ethernet, loop prevention, Link Aggregation, VLAN management
IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz
AC 100 - 240 V (50/60 Hz)
33 cm x 23 cm x 4.4 cm
2.4 kg
Europe
3 years warranty
Switch - 8 ports
Enclosure Type
Desktop, rack-mountable
Subtype
10 Gigabit Ethernet
Ports
8 x 100/1000/10000
Performance
16000 entries
Jumbo Frame Support
9216 bytes
8 x 10GBase-T RJ-45
Internal power supply
31 Watt
Rack Mounting Kit
Included
Plug and Play, FCC Class A certified, UL, CB, IC Class A, VCCI Class A
Europe
33 cm
23 cm
4.4 cm
2.4 kg
Limited warranty - 3 years
50 °C
10 - 85% (non-condensing)
Ports: 8
Brand: Buffalo
Price Range Ex VAT: 300 - 500
