Buffalo's BS-XP series of 10GbE switches offers an easy, cost-effective and energy-efficient way to extend your business network at blazing speeds. Plug and play installation requires no additional software or configuration; simply plug your network-ready devices into one of the available Ethernet ports. Each AUTO-MDIX port automatically detects and configures the correct connection while optional jumbo frame support and full duplex operation provide maximum performance.
Along with 802.3az Green Ethernet technology, the BS-XP series includes intelligent Power Control, an energy conservation feature that monitors the activity status of each port to reduce the total power consumed. Its durable, metal chassis is equipped with holes for wall-mounting or rubber feet for easy placement on a desktop.
With 10GbE speeds, eco-minded operation, performance-minded features and a lifetime warranty, Buffalo's BS-XP series of switches is a perfect network extension for your business.
- BUFFALO BS-XP Series BS-XP2012 - switch - 12 ports - rack-mountable
- Switch - 12 ports
- Enclosure Type
- Rack-mountable
- Subtype
- 10 Gigabit Ethernet
- Ports
- 12 x 10 Gigabit Ethernet
- Performance
- Latency: 10 ms , Data transfer rate: 120 Gbps
- Capacity
- Jumbo frame size: up to 9 KB , MAC addresses: 16000 , Buffer capacity (MB): 2
- MAC Address Table Size
- 16000 entries
- Jumbo Frame Support
- 9216 bytes
- VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, Quality of Service (QoS), Green Ethernet, reset button, Traffic Control, loop prevention, metal housing, Link Aggregation
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3an, IEEE 802.3az
- Power
- AC 100 - 240 V (50/60 Hz)
- 33 cm x 23 cm x 4.4 cm
- 2.57 kg
- Localisation
- Europe
- 3-year warranty
- Switch - 12 ports
- Enclosure Type
- Desktop, rack-mountable, wall-mountable
- Subtype
- Ports
- Performance
- Capacity
- 16000 entries
- 9216 bytes
- Status Indicators
- Port transmission speed, power, link/activity
- 12 x 10GBase-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 50 Watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- CB, FCC, IC Class A, VCCI Class A
- Localisation
- Europe
- 33 cm
- 23 cm
- 4.4 cm
- 2.57 kg
- Limited warranty - 3 years
- 0 °C
- 50 °C
- 10 - 85% (non-condensing)
