Buffalo Technology's LinkStation 420 series is the two bay NAS: ready for your data storage tasks with easy setup, an intuitive interface, and a free personal cloud for remote access from anywhere via web browsers or smart devices. Buffalo's LinkStation has the latest CPU with a powerful CPU core for noticeably improved performance that delivers high transfer speeds!
Built-in BitTorrent
Download media files directly to your LinkStation 420 without having to power up your PC with the built-in BitTorrent client. A BitTorrent client is a program that uses the BitTorrent protocol to manage large file downloads and uploads over the Internet. -
Buffalo's Web access technology
Buffalo's unique Web access feature allows you to easily access and share your photos, music files, and videos stored on your Buffalo NAS with anyone who has access to the Internet. No special software is required. -
Direct Stream Digital (DSD)
Stream digital music in studio quality - the LS400 series has the Direct Stream Digital (DSD) playback and streams high-end audio files without losing quality. Buffalo is working together with major Audio equipment brands to ensure compatibility with most network-capable AV receivers, players, and streamers and DSD-native and DSD over PCM file formats. -
Built-in FTP and print servers
Access your LinkStation 420 files via the built-in FTP server or print from anywhere on your network via the built-in print server, using USB 2.0 printer.
- BUFFALO LinkStation 420 NVR standalone NVR - 8 channels
- NVR - 8 channels - networked
- IP Cameras Supported
- 8
- Frame Rate
- 30 fps
- Hard Drive
- 2 x 2 TB
- Hard Drive(s) Supported
- Quantity: 2 - total capacity: 4 TB
- Voltage
- 100 - 240 V
- 8.7 cm x 20.5 cm x 12.8 cm
- 2.4 kg
- 3 years
- Bundled Services
- 3 Years 24-hours HDD Exchange
- NVR
- Video Channels
- 8
- 8
- OS Provided
- Linux
- Software Included (Y)
- AXIS Camera Companion
- Warranty
- 3 years
- Bundled Services
Security DVR
- Frame Rate (Record)
- 30 fps
- Networked
- RAID 0 support, RAID 1 support, RAID JBOD support, security lock slot (cable lock sold separately)
Hard Drive
- Quantity Installed
- 2
- Quantity Supported
- 2
- Capacity
- 2 TB
- Interface
- Serial ATA
- Removable
- Supported Max Total Capacity
- 4 TB
- Supported Protocols
- FTP, HTTP, TCP/IP, RTSP, HTTPS, SMB, LDAP, CIFS
- FTP server, Buffalo Web Access, NTP time synchronisation, SFTP server
- Network Port
- 10/100/1000Base-T
- Other Ports
- USB 2.0
- Voltage
- 100 - 240 V
- Frequency
- 50/60 Hz
- Power Consumption
- 25 Watt
- 8.7 cm
- 20.5 cm
- 12.8 cm
- 2.4 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
