Buffalo 4TB (1 x 4TB) LinkStation 210 1-Bay NAS
Quicklinx: 99NJWS00 Mfr#: LS210D0401-EU
Capacity: 4TB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
Type: 1-Bay
Select:
  • Windows 8.1 (32/64 bits)
15 in stock
£118.95 ex VAT
£142.74 inc VAT
Buffalo Technology's LinkStation 210D series makes sure you have all your data in a central place and can access it from anywhere in the world. The LS210 combines the convenience and capacity of Network Attached Storage with an incredibly easy User Interface and super-quiet fan-less operation. It is fast and ready for intensive data storage tasks and can even be set up via Smartphones with a mobile-optimized and intuitive interface. Buffalo Technology's LS210 series is a single bay Network Attached Storage available fully populated with big capacity.
  • Sorry NSA - the truly private cloud
    Without any monthly fees you can now ensure your privacy. Set up the LinkStation 210 anywhere you want and store files in your private cloud. Set up the LinkStation 210 in your home and here is your private cloud. Media files are accessible from all your DLNA devices at home.
  • Organize your life
    Ideal for home users, LinkStation 210 Series provides simple network storage and backup and offers an assortment of features, allowing users to store, organize, access and stream media files from any computer, smartphone or tablet. Buffalo's LinkStation 210 can also stream up to 4 HD films simultaneously allowing each family member to watch their favorite film, on their own device, at the same time.
  • Powerful backup NovaBACKUP
    The LinkStation 210 is bundled with five licenses of NovaBACKUP Professional. The NovaBACKUP Professional automatically backs up your personal documents along with your favorite photos, music and videos, and protects your data on workstations locally and online. Regardless of theft, user error or hardware failure, NovaBACKUP keeps your data secure.
  • Built-in BitTorrent
    Download media files directly to your LinkStation 210 without having to power up your PC with the built-in BitTorrent client.
  • Quick and easy setup
    The LS210 is fast and ready for intensive data storage tasks and can even be set up via Smartphones with a mobile-optimized and intuitive interface.
  • Direct Stream Digital (DSD)
    Stream digital music in studio quality - the LS210 series has Direct Stream Digital (DSD) playback and streams high-end audio files without losing quality. Buffalo is working together with major Audio equipment brands to ensure compatibility with most network-capable AV Receivers, Players, and Streamers and DSD-native and DSD over PCM file formats.
  • Gigabit Ethernet port 10/100/1000
    Gigabit Ethernet port enabled for high-speed network connectivity.
  • Restricted network access
    Set access to network at group and user security levels to protect data.
  • Seamlessly Wired to iTunes
    Access music files stored on your LinkStation 210 with your iTunes software.
  • Active Directory support
    Works as a client in an Active Directory domain allowing the LinkStation 210 to utilize the domain users and groups.
BUFFALO LinkStation 210 - NAS server - 4 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
4 TB
4.5 cm x 20.5 cm x 12.8 cm
1.1 kg
1 x Marvell ARMADA 370 800 MHz (Dual-Core)
Storage Controller
SATA SATA 3Gb/s
Hard Drive
1 x 4 TB SATA 3Gb/s
10Mb LAN, 100Mb LAN, GigE
RAM
256 MB
Microsoft Windows XP, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8, Microsoft Windows RT, Android 2.3 or later, Apple iOS 5.0 or later, Windows 8.1 (32/64 bits), Windows 8.1 RT
NAS server
Host Connectivity
Gigabit Ethernet
4 TB
4.5 cm
20.5 cm
12.8 cm
1.1 kg
Enclosure Colour
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
256 MB DDR3
Storage Controller
SATA
Interface Type
SATA 3Gb/s
Hard Drive
HDD
1 x 4 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP, Bonjour
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Print server, iTunes server, Buffalo Web Access, BitTorrent Client, fanless, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
Expansion Bays
1 (total) / 0 (free) x internal
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
External power adapter
12 Watt
Software Included
NovaBACKUP Workstation - Buffalo Edition (5 licences)
5 °C
35 °C
20 - 80% (non-condensing)
99NJ C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
99NJ C2G 5m USB 2.0 A/B Cable - Black In Stock £5.10
99NJ C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.97
Capacity: 4TB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Type: 1-Bay
Brand: Buffalo
Price Range Ex VAT: 100 - 150
