Buffalo 3TB DriveStation Velocity USB 3.0 External HDD Hardware Encryption
Quicklinx: 7PY9WS00 Mfr#: HD-LX3.0TU3-EU
Form Factor: 3.5"
Capacity: 3TB
Interface: SuperSpeed USB
Hurry, only 2 left in stock!
£72.01 ex VAT
£86.41 inc VAT
SuperSpeed USB 3.0 hard disk drive
DriveStation™ Velocity is the perfect solution for those who need to transfer files quickly and easily. The amazing speed performance comes from a combination of a more efficient improved USB 3.0 interface, Buffalo's enhanced TurboPC EX data transfer and copy utility and a 7,200 RPM drive. With USB 3.0, digital content transfers at speeds of up to 5Gbps*. If you haven't moved up to USB 3.0 yet - DriveStation™ Velocity is backward compatible with USB 2.0.
The unit is also optimal for users who want to restrict access to their personal drive when on a shared computer or network. Powerful yet easy-to-use security options include automatic hardware encryption that protects your data, with no loss of performance.
Features and Benefits
  • SuperSpeed USB 3.0: The USB 3.0 interface moves data at rates of up to 5 gigabytes per second*, ideal for video and other dataintensive digital content
  • TurboPC EX utility: TurboPC EX adds more performance to Buffalo's TurboPC with TurboCopy performance and copy enhancement utility for Windows. Now saving, copying, and transferring files is even faster.
  • High speed 7,200 RPM hard disk: The disk reads and writes data faster, so you spend less time waiting when transferring and saving files
  • Hardware Disk Encryption: 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorised access on Windows PCs
  • Back Up Your Files: Buffalo's Backup Utility automatically backs up your Windows PC, protecting your data
  • RAMDISK virtual disk utility: The Windows RAMDISK utility creates a small "virtual hard disk" using your computer's RAM (random access memory)
  • eco Manager: Eco minded power management tool for Windows regulates power usage, conserving energy and battery consumption
  • SuperEco: saves power consumption during stand-by mode by Auto Power OFF
  • SecureLock Manager: Easy software simplifies access for you while keeping others out on Windows PCs
  • Plug & Play Connectivity: Connecting and using the drive is simple-just plug it in to any USB port on a computer or other device you're connecting to. No need to install any drivers and no confusing settings.
  • Fully backwards compatible with USB 2.0: No adjustments are needed, just plug into any USB 2.0 port
  • 2-Year Warranty
    The USB 3.0 interface is ideal for video and other data intensive digital content.
    TurboPC EX adds more performance to Buffalo's TurboPC with TurboCopy performance and copy enhancement utility. Saving, copying, and transferring files is even faster.
  • High speed 7,200 rpm hard disk
    The disk reads and writes data faster, so you spend less time waiting when transferring and saving files.
  • Hardware disk encryption
    256-bit AES Full Disk Encryption (FDE) protects your data from unauthorized access on PCs.
  • Back up your files
    Buffalo's backup utility automatically backs up your Windows PC, protecting your data.
    The Windows RAMDISK utility creates a small "virtual hard disk" using your computer's RAM (random access memory).
  • SuperEco
    It saves power consumption during stand-by mode by auto power off.
  • Plug and Play connectivity
    No adjustments are needed, just plug into any USB 2.0 port.
BUFFALO DriveStation Velocity - hard drive - 3 TB - USB 3.0
Hard drive - external (desktop) - Hardware Full Disk Encryption (FDE), automatic backup
3 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
7200 rpm
Hardware Full Disk Encryption (FDE), automatic backup, 256-bit AES
3.9 cm x 18.9 cm x 12.3 cm
0.95 kg
3 TB
Hardware Encryption
USB 3.0
3.9 cm
18.9 cm
12.3 cm
0.95 kg
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power supply
Power Consumption
18 Watt (active)
Software Included
Buffalo Tools
Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
Plug and Play
5 °C
35 °C
20 - 80% (non-condensing)
7PY9 C2G USB 3.0 to Gigabit Ethernet Network Adapter In Stock £24.11
Resources
The following resources are available for the Buffalo 3TB DriveStation Velocity USB 3.0 External HDD Hardware Encryption
Form Factor: 3.5"
Capacity: 3TB
Brand: Buffalo
Price Range Ex VAT: 50 - 100
