Buffalo's DriveStation (HD-LCU3) is an easy-to-use, economical, and silent solution, that enables users to quickly store, access, and transfer files, digital images, documents, and back-ups. Just plug it in to almost any device with a USB port and Buffalo's DriveStation will instantly expand your storage. The HD-LCU3 features a sleek chassis, that can be positioned vertically or horizontally and has specially-designed interior bumpers to help ensure near-silent operation. Together with eco-friendly auto power on/off, Buffalo's DriveStation is a smart choice for any user.
- BUFFALO DriveStation HD-LCU3 Series - hard drive - 3 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 3 TB
- Form Factor
- 3.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Silent HDD, ECO, Apple Time Machine compatible, software encryption, power management support
- Power Source
- Included AC adapter
- 3.9 cm x 18.7 cm x 12 cm
- 1 kg
- Capacity
- 3 TB
- Form Factor
- 3.5"
- Interface
- USB 3.0
- Internal Drive Interface
- SATA 3 Gb/s
- 3.9 cm
- 18.7 cm
- 12 cm
- 1 kg
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Compatible Bay
- 3.5"
- Power Source
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Consumption
- 18 Watt (maximum)
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7 or later, Windows 8, Apple MacOS X 10.5 - 10.8, Windows 8.1, Windows 10
- Cables Included
- 1 x USB 3.0 cable - external
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
