Your basket is empty
Buffalo 2TB LinkStation 420DS 2Bay IP Camera Recording NAS for AXIS
Quicklinx: 9QD7WS00 Mfr#: LS420D0202S-EU
Buffalo Technology's LinkStation 420 series is the two bay NAS: ready for your data storage tasks with easy setup, an intuitive interface, and a free personal cloud for remote access from anywhere via web browsers or smart devices. Buffalo's LinkStation has the latest CPU with a powerful CPU core for noticeably improved performance that delivers high transfer speeds!
BUFFALO LinkStation 420 NVR standalone NVR - 8 channels
NVR - 8 channels - networked
IP Cameras Supported
8
Frame Rate
30 fps
Hard Drive
2 x 1 TB
Hard Drive(s) Supported
Quantity: 2 - total capacity: 4 TB
Voltage
100 - 240 V
8.7 cm x 20.5 cm x 12.8 cm
2.4 kg
3 years
Bundled Services
3 Years 24-hours HDD Exchange
NVR
Video Channels
8
8
OS Provided
Linux
Software Included (Y)
AXIS Camera Companion
Warranty
3 years
Bundled Services
Security DVR
Frame Rate (Record)
30 fps
Networked
RAID 0 support, RAID 1 support, RAID JBOD support, security lock slot (cable lock sold separately)
Hard Drive
Quantity Installed
2
Quantity Supported
2
1 TB
Serial ATA
Removable
Supported Max Total Capacity
4 TB
Supported Protocols
FTP, HTTP, TCP/IP, RTSP, HTTPS, SMB, LDAP, CIFS
FTP server, Buffalo Web Access, NTP time synchronisation, SFTP server
Network Port
10/100/1000Base-T
Other Ports
USB 2.0
Voltage
100 - 240 V
Frequency
50/60 Hz
Power Consumption
25 Watt
8.7 cm
20.5 cm
12.8 cm
2.4 kg
5 °C
35 °C
20 - 80% (non-condensing)
9QD7 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.09
9QD7 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.60
9QD7 C2G 2m Cat6a Shielded Patch - Blue In Stock £6.53
9QD7 C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.38
