Buffalo Technology's new LinkStation 210D series combines the convenience and capacity of Network Attached Storage with an incredibly easy User Interface and super-quiet fan-less operation.
The LS210 is fast and ready for intensive data storage tasks and can even be set up via Smartphones with a new mobile optimized and intuitive interface.
Buffalo's new LinkStation can also stream up to 4 HD films simultaneously allowing each family member to watch their favorite film, on their own device, at the same time. All of this is combined with a free personal private cloud for remote access from anywhere via apps for Tablets and Smart Phones or via web browsers: keeping all your data at your fingertips no matter where you are.
Buffalo Technology's LS210 series is a single bay Network Attached Storage available fully populated with 2 or 3TB capacity.
- BUFFALO LinkStation 210 - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- Max Supported Capacity
- 3 TB
- 4.5 cm x 20.5 cm x 12.8 cm
- 1.1 kg ()
- Processor
- 1 x Marvell ARMADA 370 800 MHz (Dual-Core)
- Storage Controller
- SATA SATA 3Gb/s
- Hard Drive
- 1 x 2 TB SATA 3Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 256 MB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8, Android 2.3 or later, Apple iOS 5.0 or later, Windows 8.1 (32/64 bits), Windows 8.1 RT, Windows RT
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 3 TB
- 4.5 cm
- 20.5 cm
- 12.8 cm
- 1.1 kg ()
- Enclosure Colour
- Black
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 256 MB DDR3
Storage Controller
- SATA
- Interface Type
- SATA 3Gb/s
Hard Drive
- HDD
- Capacity
- 1 x 2 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP, Bonjour
- Remote Management Protocol
- HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- Print server, iTunes server, Buffalo Web Access, BitTorrent Client, fanless, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- Expansion Bays
- 1 (total) / 0 (free) x internal
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
- Power Device
- External power adapter
- Voltage Required
- 12 Watt
- Software Included
- NovaBACKUP Workstation - Buffalo Edition (5 licences)
- OS Required
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
