Product
Buffalo 1TB MiniStation Thunderbolt + USB 3.0 2.5" Portable Hard Drive
Quicklinx: 8ZK5WS00 Mfr#: HD-PA1.0TU3-EU
Form Factor: 2.5"
Capacity: 1TB
Interface: Thunderbolt
Stock Status: Clearance
Hurry, only 1 left in stock!
£104.65 ex VAT
£125.58 inc VAT
Express delivery Order within the next 14 hours for delivery tomorrow
Great portable storage solution: Thunderbolt (10GBps) Interface. Two times faster Interface speed than USB 3.0.
Buffalo Technology's MiniStation Thunderbolt Portable HDD is world's first portable Thunderbolt with an USB 3.0 dual interface external drive solution. The Thunderbolt (10 GBps) Interface is twice as fast than USB 3.0 while pr serving backward compatibility with existing devices that support USB 2.0 or USB 3.0.
Apple friendly
The MiniStation Thunderbolt™ Portable HDD can be formatted to support both PC and Mac® making it a great portable storage solution for any device. Native Compatibility with Mac OS X Time Machine also makes it an ideal solution for backup with Mac computers.
Bus powered
Bus-powered, the MiniStation Thunderbolt™ Portable HDD requires no additional power supply and is easy to carry. Just plug the portable HDD body with the included Thunderbolt Cable* onto your Mac. Housed in a sleek aluminum body with a transparent frosted top, the design feels luxurious. MiniStation Thunderbolt™ Portable HDD features an indirect disk access LED indicator on the underside that tastefully illuminates its supporting surface.
With the MiniStation Thunderbolt™ Portable HDD on the move, you can transfer digital content faster, simplify connections between devices, maintain compatibility with nearly any device and enjoy new ways to use portable storage.
*No AC adapter is required
  • Ultimate speed: Thunderbolt (10GBps) Interface. Two times faster Interface speed than USB 3.0.
  • Dual-interface: Two extremely fast interfaces: Thunderbolt and USB 3.0.
  • Cables included: Thunderbolt and USB 3.0 cables in the box.
  • Bus powered: No additional power input required.
  • Apple friendly: Ready for use for Mac immediately and Works for Mac TimeMachine (HFS+ formatted).
  • Design: Sophisticated design.
Specification
  • HDD Interface: SATA
  • Capacity 1TB
  • Connector TypeThunderbolt (Mini DisplayPort)
  • Data Transfer Rates10Gb/s
  • Connector TypeMicro-B USB
  • Standard ComplianceUSB 3.0
  • Data Transfer Rates5Gb/s
  • Dimensions (W x D x H)80.5 x 130 x 22.5 mm
  • Weight 260g
  • OS Support Thunderbolt - Mac OS X 10.6 or later, USB - Mac OS X 10.5 or later, Windows 7 (64-bit/32-bit) / Vista (64-bit/32-bit) / XP(32-bit)
  • Operating Environment5-35°C, 20-80% (non-condensing)
  • Power Supply USB bus powered
  • Ultimate speed
    Thunderbolt (10 Gbps) interface. Two times faster Interface speed than USB 3.0.
  • Dual-interface
    Thunderbolt and USB 3.0 for the best possible speeds.
  • Bus powered
  • Design
BUFFALO MiniStation Thunderbolt - hard drive - 1 TB - USB 3.0 / Thunderbolt
Hard drive - external (portable)
1 TB
Data Transfer Rate
10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
Apple Time Machine compatible, HFS+ formatted
Power Source
USB bus, Thunderbolt bus
80.5 mm x 130 mm x 22.5 mm
260 g
Apple iMac; Mac mini; MacBook Air; MacBook Pro
1 TB
Internal Drive Interface
Serial ATA
80.5 mm
130 mm
22.5 mm
260 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B , 1 x Thunderbolt - Mini DisplayPort
Power Source
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple MacOS X 10.5 - 10.8
1 x USB 3.0 cable - external , 1 x Thunderbolt cable - external
5 °C
35 °C
20 - 80% (non-condensing)
Apple iMac , Apple Mac mini , Apple MacBook Air , Apple MacBook Pro
Form Factor: 2.5"
Capacity: 1TB
Brand: Buffalo
Price Range Ex VAT: 100 - 150
