Your basket is empty
Buffalo 1TB MiniStation Extreme USB 3.0 Water & Dust Resistant Portable Hard Drive - Black
Quicklinx: BK48WS00 Mfr#: HD-PZF1.0U3B-EU
Form Factor: 2.5"
Capacity: 1TB
Interface: USB 3.0
£63.97 ex VAT
£76.76 inc VAT
Express delivery Order within the next 12 hours for delivery tomorrow
MiniStation™ Extreme - The perfect solution for those who often travel with PCs and portable HDDs
BUFFALO’s MiniStation™ Extreme offers high performance USB3.0 portable storage in a compact and sophisticated design. The internal hard drive is encased in a highly shock-resistant body with rubberised elements to protect it from accidental bumps.
The ingenious arrangement of shock protection features meets the U.S. Military Standard MIL-STD-810G, METHOD 516.6, Procedure IV and has passed free-fall drop tests with drops up to 2.3 meters.
Moreover, the USB cable is integrated with the case so you will not be frustrated searching for a cable anymore!
The USB 3.0 interface moves data at rates of up to 5Gbps. This vastly reduces the time needed for data transmission, making it ideal for transferring and sharing videos, large digital photo collections, music files, and other data-intensive digital content. MiniStation Extreme is available with 1TB or 2TB capacities. Both capacities are available in black; 1TB capacity is also available in red or silver.
Highly Shock-Resistant
Buffalo™ gave the HD-PZFU3 a sleek design with an attractive matte finish and Buffalo’s patented shock-proof chassis: U.S. military-grade shock protection helps protect the hard drive from damage, passing 2.3-meter free-fall drop test.
Water and Dust-Resistant
Complies with standard IPX3:
Spraying water from angles up to 60° from the vertical shall have no harmful effect.
Complies with Standard IP5X:
Dust will not interfere with the satisfactory operation.
Want more protection?
Hardware Disk Encryption: 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorised access. This type of encryption has never been broken and governments and businesses place a great deal of faith that it never will be.
Easy Cable Management
Integrated USB3.0 cable snaps to chassis for pack-and-go-portability.
BUFFALO MiniStation Extreme - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Shock resistant, water resistant, Hardware Full Disk Encryption (FDE), dust-proof, wrap-around USB cable, Apple Time Machine compatible, 256-bit AES
Power Source
USB bus
Enclosure Colour
9 cm x 14.1 cm x 2.1 cm
277 g
2 years warranty
1 TB
Hardware Encryption
USB 3.0
Internal Drive Interface
SATA 3 Gb/s
9 cm
14.1 cm
2.1 cm
277 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7 or later, Windows 8, Microsoft Windows RT, Windows 8.1 RT, Windows 8.1
1 x USB 3.0 cable - integrated
MIL-STD 810G 516.6, IP5X, IPX3
Enclosure Colour
5 °C
35 °C
20 - 80% (non-condensing)
Form Factor: 2.5"
Capacity: 1TB
Interface: USB 3.0
Brand: Buffalo
Price Range Ex VAT: 50 - 100
