Huge Capacity Direct Attached Storage Fully populated with high-reliability WD Red™ drives
Buffalo Technology's DriveStation™ Quad (HD-QHU3 series) is a 4-bay Direct Attached Storage device perfect for demanding SMB. The HD-QHU3 comes fully populated with high-reliability WD Red™ drives in total capacities of up to 24TB.
The DriveStation™ Quad is RAID-enabled for customised redundancy and capacity depending on your specific needs and also comes with 10 licenses of NovaStor NovaBACKUP Business Essentials software.
The DriveStation™ Quad features the capacity, redundancy, and performance required for any demanding user - the perfect solution for backing up large servers, multimedia files, or databases. The HD-QHU3 series is sold fully populated with WD Red drives and total capacities of 8, 12, 16, or 24TB.
- BUFFALO DriveStation Quad USB 3.0 - hard drive array
- Hard drive array
- Total Array Capacity
- 16 TB
- Max Supported Capacity
- 24 TB
- Interface
- USB 3.0
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- Supported Drives
- SATA-300
- Storage Controller
- RAID (SATA 3Gb/s) - RAID RAID 0, 1, 5, 10, JBOD
- Hard Drive
- 4 x 4 TB HDD SATA 3Gb/s - hot-swap
- OS Required
- Microsoft Windows XP, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows XP Media Center Edition 2005, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Android 2.3 or later, Microsoft Windows Server 2012 (32/64-bits), Apple iOS 5.0 or later, Windows 8.1 (32/64 bits), Windows Phone 8, Microsoft Windows RT 8.1, Microsoft Windows RT 8, Microsoft Windows Phone 7.5
- Power
- AC 120/230 V - 50/60 Hz
- 14.9 cm x 23.3 cm x 15.4 cm
- 5.5 kg
- 3-year warranty
- Hard drive array
Chassis
- 4
- Supported Devices / Modules Qty
- 4
- Supported Drives
- SATA-300
Storage
- 16 TB
- 24 TB
- HDD Array External Interface
- USB 3.0
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 4 TB
- Interface Type
- SATA 3Gb/s
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap
- 1 x USB 3.0 - 9 pin USB Type B
- OS Required
- Software Included
- Buffalo Tools, SecureLockMobile, NovaBACKUP Business Essentials (10 licences)
- Plug and Play
- Power Device
- External power adapter
- Voltage Required
- 90 Watt
- 14.9 cm
- 23.3 cm
- 15.4 cm
- 5.5 kg
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
