Product
BT Whole Home Wi-Fi Quad Bundle - 1x Twin and 2x Add-on Discs
Quicklinx: DV75WS00 Mfr#: 095663
Type: Radio access point
Connectivity: Wireless
Speed: 1733Mbps
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • IEEE 802.11n
More than 50 in stock
£233.33 ex VAT
£279.99 inc VAT
Express delivery Order within the next 13 hours for delivery tomorrow
Superfast, super-reliable Wi-Fi for every room
Works with all broadband providers
You don’t need to have broadband with BT to use Whole Home Wi-Fi. Just connect the discs to your existing router or hub using the app and you’ll have wi-fi all around your home in minutes.
Four discs, Wi-Fi everywhere
Designed specifically for larger homes with 6+ bedrooms, BT's Whole Home Wi-Fi Quad Pack delivers superfast, super-reliable Wi-Fi for every room. Four brilliant discs create a complete Wi-Fi network. Eliminates deadspots and gets you connected on multiple devices, everywhere in your home.
Wi-Fi at its finest
Whole Home Wi-Fi comes with an app to give you complete control. It helps you find the best location for each disc during set up, shows who is connected and even lets you pause the internet for some time offline.
The technical bit
Whole Home Wi-Fi is an "intelligent self-configuring wireless network". That means it knows where you and your devices are and when to automatically switch them from one disc to another to give you the strongest and fastest connection it can. The two discs might be small, but their four built-in 2.4GHz and 5GHz antennas pack a mighty AC2600 wireless punch and incorporate the latest in Wi-Fi security.
Stay connected
Four discs create a complete Wi-Fi network, eliminating deadspots and making sure you're connected on every device, everywhere in your home.
Complete control
Use the app for simple set up, see who's online and even pause the internet.
Super smart
Our intelligent Wi-Fi technology automatically connects you to the fastest and strongest signal as you move from room to room.
What's in the box?
  • The bundle contains 1x WHW Twin and 2x WHW Add-on discs
  • 4 x 11ac Dual-Band Wi-Fi Discs
  • 4 x Power Supply Units
  • Ethernet Cable
  • Quick Start Guide
  • Works with any broadband provider
    You don't need to have broadband with BT to use whole home Wi-Fi. Just connect the discs to your existing router or hub using the app and you'll have Wi-Fi all around your home in minutes.
  • Four discs, Wi-Fi everywhere
    Designed specifically for larger homes with 6+ bedrooms, BT's whole home Wi-Fi quad pack delivers superfast, super-reliable Wi-Fi for every room. Four brilliant discs create a complete Wi-Fi network. Eliminates deadspots and gets you connected on multiple devices, everywhere in your home.
  • Wi-Fi at its finest
    Whole home Wi-Fi comes with an app to give you complete control. It helps you find the best location for each disc during set up, shows who is connected and even lets you pause the Internet for some time offline.
  • The technical bit
    Whole home Wi-Fi is an "intelligent self-configuring wireless network". That means it knows where you and your devices are and when to automatically switch them from one disc to another to give you the strongest and fastest connection it can. The two discs might be small, but their four built-in antennas pack a mighty AC2600 wireless punch and incorporate a high level of Wi-Fi security.
  • Stay connected
  • Complete control
    Use the app for simple set up, see who's online and even pause the Internet.
  • Super smart
    The intelligent Wi-Fi technology automatically connects you to the fastest and strongest signal as you move from room to room.
BT Whole Home Wi-Fi - radio access point
Radio access point
Packaged Quantity
4 (specifications are for single item)
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
16.5 cm x 7.7 cm x 16.5 cm
415 g
2 years warranty
Packaged Quantity
Radio access point
16.5 cm
7.7 cm
16.5 cm
415 g
External
Wireless
Data Transfer Rate
1733 Mbps
Line Coding Format
256 QAM
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
WPS, starting, connection status
Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPS
IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
Aerial
Antenna
Internal
Antenna Qty
4
1 x 1000Base-T - RJ-45 (WAN)
1 x network cable
External power adapter
7.09 Watt
10 - 85%
Speed: 1733Mbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Brand: BT
Price Range Ex VAT: 150 - 300
