Get Wi-Fi in every room or your money back!*
*30 day money back guarantee from date of purchase. The Whole Home Wi-fi app helps you position the discs to ensure you get complete coverage. If you still experience dead spots and are not satisfied you can return the product for a full refund. The product must be undamaged and in the original packaging. Your wi-fi speed will depend on your broadband input speed.
Works with all broadband providers.
You don’t need to have broadband with BT to use Whole Home Wi-Fi. Just connect the discs to your existing router or hub using the app and you’ll have wi-fi all around your home in minutes.
Internet from the loft to the cellar. And in every room between.
Staying glued to that box set season finale from living room to bath. Video calling your family on the other side of the world. Changing a fuse, with a YouTube tutorial guiding the way beside you. Sifting through boxes of memories in the loft, to the soundtrack of your teens.
Wherever you are in your home, Whole Home Wi-Fi puts what matters most at your fingertips. It brings super-fast, super-reliable Internet to every room. It talks to all your gadgets to make sure they're always connected to the fastest and strongest signal. And it's bristling with brilliant controls that put you in charge of a supercharged home network.
No more deadspots
With Whole Home Wi-Fi you can have your favourite TV, films, music and games in any room you wish. Three brilliant discs create a complete Wi-Fi network - which means no more deadspots. Even when there are multiple devices connected you still won't lose speed, so you can have a laptop connected in the kitchen, games consol upstairs and a tablet in the lounge - and they'll all stay connected, all the time.
The technical bit
Whole Home Wi-Fi is an "intelligent self-configuring wireless network". That means it knows where you and your devices are, and when to switch them from one disc to another to give you the strongest and fastest connection it can. The three discs might be small, but their four built-in AC2600 11ac 2.4GHZ and 5GHZ antennas pack a mighty wireless punch.
Keeping you safe
Whole Home Wi-Fi uses the latest security standards to keep your home network safe from outside interference. And one touch updates mean your home is always protected by the latest up-to-the-minute security patches and upgrades.
With brand new technology, one touch software updates and an app to control it all from, this is Wi-Fi at its simplest. It's Internet that just works.
You're in charge
First, the Whole Home Wi-Fi app tells you just where to put each disc for the best connection. Then once everything's working, it puts you in charge.
Want to see who's hogging your connection?
A helpful dashboard to see how your network is being used and who is connected.
Want to get everyone down for dinner? Or just get some time offline?
Pause the internet completely with one tap.
Disc lights too bright for your bedroom?
Turn them down, or off completely.
Technical gremlins?
The app will spot - and explain how to fix - them.
Legals - 30 day money back guarantee from date of purchase. The Whole Home Wi-fi app helps you position the discs to ensure you get complete coverage. If you still experience dead spots and are not satisfied you can return the product for a full refund. The product must be undamaged and in the original packaging. Your wi-fi speed will depend on your broadband input speed.
Superior Wi-Fi
Whole Home Wi-Fi helps you find a better location for each disc during set up, shows who is connected and even lets you pause the Internet for some time offline. -
The technical bit
Whole Home Wi-Fi is an intelligent self-configuring wireless network. That means it knows where you and your devices are and when to automatically switch them from one disc to another to give you better performance. -
Stay connected
The discs create a complete Wi-Fi network, eliminating dead spots and making sure you're connected on every device, everywhere in your home. -
Not compatible with Complete WiFi (Black Discs)
These are not compatible with complete (WiFi) or Mini, premium or WiFi 6 discs
Customer reviews
Write a review for the BT Whole Home Wi-Fi here!
Mr
Reviewed by Opti-Fi. Review Posted 21/07/2018
Not having the ability to remove the 5Ghz Band from the Whole Homes causes a problem with Sky Q interfering with the 5G band on the whole home. A firmware update allowing this would benefit a lot of my customers as Sky Broadband is not available in this location, therefore the sky Q boxes are not and cannot be used for the Wi-Fi network. Please send me a firmware update enabling this action.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
