BT Whole Home Wi-Fi - Twin Pack
Quicklinx: F4SSWS00 Mfr#: 092099-BTBD
  • IEEE 802.11n
Designed specifically for flats and smaller homes, BT's Whole Home Wi-Fi delivers fast, super-reliable Wi-Fi for every room.
  • Superior Wi-Fi
    Whole Home Wi-Fi helps you find a better location for each disc during set up, shows who is connected and even lets you pause the Internet for some time offline.
  • The technical bit
    Whole Home Wi-Fi is an intelligent self-configuring wireless network. That means it knows where you and your devices are and when to automatically switch them from one disc to another to give you better performance.
  • Stay connected
    The discs create a complete Wi-Fi network, eliminating dead spots and making sure you're connected on every device, everywhere in your home.
BT Whole Home Wi-Fi - Twin Pack - Wi-Fi system - 802.11a/b/g/n/ac - desktop
Wi-Fi system
Enclosure Type
Desktop
Wi-Fi System Components
2 access points
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
Remote Management Protocol
HTTP
Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
AC 230V (50 Hz)
16.5 cm x 7.7 cm x 16.5 cm
415 g
3-year warranty
Wi-Fi system
2 access points
Enclosure Type
Desktop
Wireless
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
HTTP
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPS
Wi-Fi AC Rating
AC2500
Status Indicators
WPS, starting, connection status
Line Properties
Line Coding Format
256 QAM
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
Installed Qty
2
AC 230V (50 Hz)
7.09 Watt
1 x network cable
16.5 cm
7.7 cm
16.5 cm
415 g
Limited warranty - 3 years
10 - 85%
