BT Smart Hub
BT Smart Hub
7 WI-FI ANTENNAES DELIVERING FASTER SPEEDS IN HARDER TO REACH ROOMS!
New
Quicklinx: C6NXWS00 Mfr#: 088138
Please note: The BT Smart Hub will only work with BT broadband.
BT's Smart Hub offers customers the UK's most powerful Wi-Fi signal compared to routers from other major broadband providers. With the very latest advances in Wi-Fi technology, the new BT Smart Hub has a combination of unique features that will allow consumers to enjoy Wi-Fi in more places with fewer dropped connections and faster speeds in harder to reach rooms.
Smart Hub Features
1. More powerful Wi-Fi: The BT Smart Hub is designed with an incredible 7 Wi-Fi antennae, which is more than any other major broadband provider's router, giving an unbeatable wireless range and a more powerful signal around your home.
2. Superfast Wi-Fi: The BT Smart Hub uses the very latest 11ac and MiMo Wi-Fi technology to give superfast wireless speeds for all your devices at the same time.
3. Filter out interference: The BT Smart Hub has built in advanced filters which automatically block interference, preventing your signal from dropping out.
4. Unique smart scan technology: The BT Smart Hub checks to see how well your hub and network connection is performing, to give you the best Wi-Fi experience at all times
The BT Smart Hub is also designed to fit through most letterboxes so customers don't need to worry about being home when it's delivered, and comes with a handy wi-fi card and sticker so customers can easily find their wi-fi password. Customers can also control the lights on the hub, choosing to either dim them or switch them off.
All BT Broadband customers get unlimited access to more than five million BT Wi-fi hotspots across the UK, helping them stay connected when they are out and about. Plus, customers signing up to the new deals will also get peace of mind that everything that's important is kept safe and secure online with BT Protect, BT Parental Controls and BT Cloud. BT is the only UK broadband provider to offer at least 100GB storage with all its new unlimited broadband packages.
- Type ADSL / FIBRE Router for use on BT Broadband only
- Router type ADSL, ADSL2+ and VDSL2
- Network protocol IPV4 and IPV6
- Recommended use Browsing the web, streaming 4K video, gaming, etc. Home gateway router
- Colour Black
- Simultaneous Dual-band
- Supported frequencies Yes 2.4GHz (3 x 3 11n MIMO, 5GHz 4x4 11ac)
- Data transfer rate Max Physical interface rates are 2.4GHz = 217Mb/s 5GHz = 1733Mb/s
- Beam forming Yes Beamforming. (implicit and Explicit Beamforming)
- Number of antennas 7 (3x2.4GHz, 4x5GHz)
- Data transfer rate Between LAN to WAN then 1G or WAN max line speed upto 300mbits
- Number of Gigabit Ethernet ports 4 x Gigabit Ethernet LAN
- Number of 10/100 Ethernet ports 0
- USB 2.0 1
- Other ports 1 x RJ45
- Encryption WPA2, WPA (Auto)
- Firewall Y
- Box contents BT Smart Hub, Power cable and plug, User guide, Extra settings card sticker
- Dimensions H41 xW410 D192
- Weight 782g
- Manufacturer's guarantee 1 year warranty
1 Year Warranty
Resources
The following resources are available for the BT Smart Hub
