Take us with you on your adventures...
Charge your devices on the go with the BT Shop branded Veho Verto Pebble charger!
Powerful & portable!
The Pebble Verto portable charger comes with 4 connecting tips to charge your favourite mobile devices! It packs a 3700 mAh, which is over 2 times the regular battery of the Apple iPhone or regular smartphone. Keep your devices running on the go and don't worry about running low on juice!
Your new holiday companion...
The Pebble Verto is perfect for festivals, camping trips, traveling abroad or as an emergency power pack for those busy days when your battery just can't keep up. The Pebble Verto will charge almost any portable device with connectors for the most popular smartphones/USB charged devices/Veho MUVI and 360° range.
Small, light, white, cool
Light to carry and small enough to fit in your pocket, this portable charger can be taken anywhere! White in colour and stamped with the BT Shop logo, the Veho Pebble is a must-have accessory that goes with everything!
- Veho Pebble Verto power bank - USB
- Product Type
- Power bank
- 6.5 cm x 9 cm x 1.4 cm
- 92.6 g
- White
- Output Connector Type
- USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 1000 mA
- Battery
- 3700 mAh
- Standby Time
- 1000 h
- Product Type
- Power bank
- 6.5 cm
- 9 cm
- 1.4 cm
- 92.6 g
- Enclosure Colour
- White
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
- 1000 mA
- Short circuit protection, overcharging protection, over-current protection, overdischarging protection
- Capacity
- 3700 mAh
- Standby Time
- 1000 h
- LED power meter, on/off button
- Included Accessories
- USB charging cable, carrying pouch, 4 connector tips
