Product
Brand
BT Shop Pebble Verto Portable 3700mAh Charger
Quicklinx: CWKLWS00 Mfr#: VPP-201-CW@BT
Take us with you on your adventures...
Charge your devices on the go with the BT Shop branded Veho Verto Pebble charger!
Powerful & portable!
The Pebble Verto portable charger comes with 4 connecting tips to charge your favourite mobile devices! It packs a 3700 mAh, which is over 2 times the regular battery of the Apple iPhone or regular smartphone. Keep your devices running on the go and don't worry about running low on juice!
Your new holiday companion...
The Pebble Verto is perfect for festivals, camping trips, traveling abroad or as an emergency power pack for those busy days when your battery just can't keep up. The Pebble Verto will charge almost any portable device with connectors for the most popular smartphones/USB charged devices/Veho MUVI and 360° range.
Small, light, white, cool
Light to carry and small enough to fit in your pocket, this portable charger can be taken anywhere! White in colour and stamped with the BT Shop logo, the Veho Pebble is a must-have accessory that goes with everything!
Veho Pebble Verto - power bank
Power bank
6.5 cm x 9 cm x 1.4 cm
92.6 g
Output Connector Type
USB
5 V
Voltage Provided
5 V
3700 mAh
Standby Time
1000 h
Power bank
6.5 cm
9 cm
1.4 cm
92.6 g
Enclosure Colour
White
5 V
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Max Electric Current
1000 mA
Short circuit protection, overcharging protection, over-current protection, overdischarging protection
3700 mAh
Standby Time
1000 h
LED power meter, on/off button
USB charging cable, carrying pouch, 4 connector tips
