BT Premium Whole Home Wi-Fi two discs
Quicklinx: F7BWWS00 Mfr#: 093592
32 in stock
£166.66 ex VAT
£199.99 inc VAT
Push faster, stronger wi-fi to every corner of your home
Perfect for bigger families or households with multiple users streaming content or gaming at the same time. The best solution for maintaining faster, stronger wi-fi in every room.
The latest tri-band technology pushes faster, stronger wi-fi to every corner of your home
  • The third high-speed channel you get with tri-band allows more devices to connect, and do more at the same time.
  • Perfect for bigger families or homes with lots of users streaming content or gaming all at the same time
The super smart app locates the best place for your discs, and gives you ultimate control over your broadband
  • See who’s online, pause the internet and manage a guest network. Control and schedule access, user by user
  • Triband AX3700 technology gives multiple users our speediest wi-fi. So everyone can watch, stream and download at the same time
  • Two premium discs eliminate dead spots, creating our most powerful wi-fi network. Get every device connected everywhere in your home
Intelligent wi-fi that covers the whole home
  • Placing the discs around your home gives you full control and gets rid of wi-fi dead spots
  • Automatically connects your devices to the fastest, strongest signal as you move around
  • Even with multiple devices connected you won't lose speed anywhere in your home
Now you can have TV, films, music and games on any device, in any room, with no dead spots or drop-outs.
*Premium Whole Home Wi-Fi adds a third Wi-Fi radio for "tri-band" which offers a dedicated high power connection between discs that utilises brand new 802.11ax (Wi-Fi 6) technology to deliver ultrafast speeds around the home
Restrictions - Premium Whole Home Wi-Fi can only be used in England, Wales, Scotland and Northern Ireland. As it may use frequencies in the 5.725-5.825GHz band which are not allowed elsewhere in Europe.
  • Push faster, stronger Wi-Fi to every corner of your home
    Perfect for bigger families or households with multiple users streaming content or gaming at the same time. The best solution for maintaining faster, stronger Wi-Fi in every room.
  • The latest tri-band technology pushes faster, stronger Wi-Fi to every corner of your home
    The third high-speed channel you get with tri-band allows more devices to connect, and do more at the same time. Perfect for bigger families or homes with lots of users streaming content or gaming all at the same time.
  • The super smart app locates the best place for your discs, and gives you ultimate control over your broadband
    See who's online, pause the internet and manage a guest network. Control and schedule access, user by user. Triband AX3700 technology gives multiple users speediest Wi-Fi. So everyone can watch, stream and download at the same time. Two premium discs eliminate dead spots, creating most powerful Wi-Fi network. Get every device connected everywhere in your home.
BT Premium Whole Home Wi-Fi - radio access point
Radio access point
Packaged Quantity
2 (specifications are for single item)
External
IEEE 802.11ax, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
3-year warranty
Packaged Quantity
Radio access point
External
Tri-band Wireless technology
IEEE 802.11ax 5GHz, 802.11a/n/ac 5GHz, 802.11b/g/n 2.4GHz
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
WPS, starting, connection status
Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPS
IEEE 802.11ax, IEEE 802.11ac, IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
Aerial
Antenna
Internal
Antenna Qty
6
1 x 1000Base-T - RJ-45 (WAN)
1 x network cable
External power adapter
Limited warranty - 3 years
10 - 85%
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: F7BW 042561
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £132.43
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Premium Whole Home Wi-Fi
Connectivity: Tri-band Wireless Technology
Protocol: 802.11a/n/ac 5GHz
Protocol: 802.11b/g/n 2.4GHz
Protocol: IEEE 802.11ax 5GHz
Antennas: 6
Brand: BT
Stock Status: Used Stock
Price Range Ex VAT: 150 - 300
