BT Mini Whole Home Wi-Fi Four Discs
Quicklinx: FG7WWS00 Mfr#: 101550
  • IEEE 802.11n
More than 50 in stock
£83.33 ex VAT
£99.99 inc VAT
Express delivery Order within the next 10 hours for delivery tomorrow
Extend your wi-fi throughout your home
Perfect for families or households that want all their devices connected to a strong, fast wi-fi signal in every room.
Intelligent wi-fi that covers the whole home
  • Placing the discs around your home gives you full control and gets rid of wi-fi dead spots
  • Automatically connects your devices to the fastest, strongest signal as you move around
  • Even with multiple devices connected you won't lose speed anywhere in your home
Now you can have TV, films, music and games on any device, in any room, with no dead spots or drop-outs.
The super smart app locates the best place for your discs, and gives you ultimate control over your broadband
  • Use the app to view your network, see who's online and even pause the internet
  • Dual-band AC1200 wi-fi gives you fast wi-fi as you move from room to room
  • Three discs remove dead spots, creating a complete wi-fi network, so every device stays connected everywhere in your home
These discs only work with other Mini Whole Home Wi-Fi discs
  • Intelligent Wi-Fi that covers the whole home
    Placing the discs around your home gives you full control and gets rid of Wi-Fi dead spots. It automatically connects your devices to the fastest, strongest signal as you move around. Even with multiple devices connected you won't lose speed anywhere in your home. Now you can have TV, films, music and games on any device, in any room, with no dead spots or drop-outs.
  • Locates the best place for your discs, and gives you ultimate control over your broadband
    Use the app to view your network, see who's online and even pause the Internet. Dual-band AC1200 Wi-Fi gives you fast Wi-Fi as you move from room to room. Three discs remove dead spots, creating a complete Wi-Fi network, so every device stays connected everywhere in your home.
BT Mini Whole Home Wi-Fi - radio access point
Radio access point
Packaged Quantity
4 (specifications are for single item)
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 866 Mbps
12 cm x 12 cm x 5 cm
3-year warranty
Packaged Quantity
Radio access point
12 cm
12 cm
5 cm
External
Wireless
Data Transfer Rate
866 Mbps
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AC1200
Status Indicators
WPS, starting, connection status
Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPS
IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
Aerial
Antenna
Internal
Antenna Qty
4
1 x 1000Base-T - RJ-45 (WAN)
1 x network cable
External power adapter
Limited warranty - 3 years
10 - 85%
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: FG7W 043131
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £81.10
Ref: FG7W 043151
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £78.40
Ref: FG7W 043159
Condition: Customer return - item has been opened but is in excellent condition
Ref: FG7W 043102
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £77.50
Ref: FG7W 043108
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £75.69
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Radio access point
Connectivity: Wireless
Speed: 866Mbps
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Brand: BT
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
