Your basket is empty
BT Mini Hub Kit
Quicklinx: C6NYWS00 Mfr#: 086022
Supersize your Wi-Fi!
Here’s a great way to extend the reach of your home wi-fi. Just add a BT Mini Hub. It’s a powerful wi-fi signal extender that works beautifully with the BT Smart Hub.
Want Wi-Fi in more places?
Now you can extend the reach of your home wi-fi. The BT Mini Hub sends your home hub’s wi-fi signal through your electricity lines, then broadcasts again to cover those hard-to-reach places.
You can use as many BT Mini Hubs as you like, and build your home wi-fi so it covers every area you want.
Use your BT Mini Hub to get wi-fi where you want. Maybe in the garden…
Fully compatible
The BT Mini Hub works brilliantly with most hubs, particularly the BT Smart Hub.
Smart tech
The BT Mini Hub uses your home’s mains electricity to carry your wi-fi signals.
Keep on adding
You can add as many BT Mini Hubs as you like to build a big, reliable network.
Optimise your wi-fi with the MyBT app
Download the MyBT app and try our great new wi-fi optimiser. It lets you measure the wi-fi performance around your home, then it generates a unique report that shows you how you could improve your wi-fi performance in each room.
If you’ve got an Apple or Android phone, just text ‘MyBT’ to 81192 and we’ll send you a link to download the app.
