BT Halo Single
BT Halo Single
Quicklinx: C6R3WS00 Mfr#: 084365
Select:
  • Single
The BT Halo brings style and performance to your home phone. Using the latest Bluetooth technology, the BT Halo allows you to receive mobile calls from your home phone. Premium materials and an elegant design created in collaboration with an award winning UK design agency mean this phone wouldn't look out of place in an art gallery.
Built into the phone is our nuisance call blocking technology*, which allows you to take control of all your incoming calls. Plus, with mobile syncing capabilities you can sync and store up to 2000 of your contacts onto your home phone.
Make and receive mobile and landline calls from your BT Halo
The inclusion of Bluetooth technology means that you can avoid mobile signal dropouts as you walk around the house, all from the comfort of your BT Halo.
The BT Halo's Bluetooth functionality means you can connect your mobile to your Halo base unit from up to 10m away. So long as your mobile is in a spot with good mobile coverage you can then wander freely around your home using your Halo handset to make and receive mobile calls, even in areas where you don't have mobile coverage.
Call Blocking Technology* allows you to block up to 100% of nuisance calls.
With the amazing multi-award winning trueCall technology built-in, the BT Halo can intercept callers not on your contact list to put you in control of who you speak to. You can block international and up to 1,000 numbers.
The premium call blocking feature screens incoming calls so you'll never have to speak to another cold caller again.
  • Numbers on your contact list get straight through
  • Numbers you've previously blocked will never get through
  • For anyone else, they'll have to say their name before getting to speak to you, you can then decide to accept or decline their call.
Call blocking can be done in a number of ways
  • Block by number or by call type: BT Halo blocks calls you want to block. For example, mobile, international, withheld, unavailable or payphone numbers can all be blocked.
  • Block by call type: Plus you can even block numbers by location (i.e. Use the area code or a suffix).
  • Do not disturb: For those times when you just want some peace and quiet, switch on Do Not Disturb so that your phone won't ring or light up.
  • Sync and store your mobile contacts on your BT Halo
With the ability to sync up to 2,000 of your mobile contacts, you'll always have your contacts on hand.
The BT Halo will also allow you to sync up to 2 smart phones so you can sync between the 2.
Other features
  • 1.8" Colour Screen
  • Hands free speaker
  • Record up to 60 minutes of messages
  • 3000 Name & Number directory
  • Outgoing call controls (PIN protect calls to premium / mobile numbers)
  • Backlit keypad for easy dialling even in poor light
  • Long range reception up to 300m outdoors, 50m indoors
  • Do not disturb mode
  • Up to 21 hours of talking and 240 hours on standby
  • Easy access to BT calling features (3 way calling, call divert)
  • See and hear if you have a second call waiting
*You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Resources
The following resources are available for the BT Halo Single
