BT Everyday Phone without Answer Machine - Two Handsets
Quicklinx: D9R9WS00 Mfr#: 090662
Type: Cordless phone
Handsets Included: 2
Answer Machine: No
Nuisance Call Blocker: Yes
Mounting: Table-top
Select:
27 in stock
£29.16 ex VAT
£34.99 inc VAT
The Everyday Phone Nuisance Call Blocker, gives you back control over which calls you want to take and which you want to block. The Everyday Phone can block 20 individual numbers, meaning that you really can avoid speaking to the people you don't want to. For those times when you just want some peace and quiet, switch on Block All so that your phone won't ring. If you want key friends and family to still get through, they can do, by tagging them as VIP's in your address book. Easy set up and long range reception, up to 300m outdoors, 50m indoors.
Nuisance Call Blocking
Only talk to the people you want to by blocking up to 20 numbers*.
For peace and quiet, switch on Do Not Disturb so that your phone won't ring or light up.
Easy to Use
Our BT phones have excellent sound quality with volume adjustment to suit your needs.
See whose calling before answering on the 1.5" amber display.
Freedom to move in your house
Save up to 50 contact. All these contacts are automatically copied to all of your handsets
Adjust the volume if the caller is too loud or too quiet
Box Contains
1 x Base Unit including charger
1 x Additional charger
2 x Handsets
Rechargeable batteries
2 x Mains power adaptor
1 x Telephone line cord
User Guide
  • Nuisance Call blocking features
  • Do Not Disturb
BT Everyday Phone Twin - cordless phone with caller ID + additional handset
Cordless phone with caller ID + additional handset
Total Number of Wireless Handsets
2
Cordless Phone Standard
DECT\GAP
Speakerphone
Call Services
Call Waiting, Call Transfer
Display
LCD display - monochrome - Yes
Cordless phone
Additional Handsets Qty
1
2
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID
Max Handsets Supported
5
Max Base Units Supported
4
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
300 m
Dialer Location
Handset
Conference Call Capability
Speakerphone
Volume Control
Ring Tones
5
Handset Locator
Indicators
Visual ringer light
Additional Functions
Call timer, built-in clock, Alarm, Intercom
Phone Memory
Phone Directory Capacity
50 names & numbers
Caller ID Memory
20 names & numbers
Display
Display Location
Handset
Diagonal Size
1.6"
Backlit
Placing / Mounting
Table-top
Phone charging stand
AAA type
500 mAh
Rechargeable - Nickel Metal Hydride
Talk Time
Up to 600 min
Standby Time
Up to 100 h
Dimensions & Weight (Base)
10.4 cm
11.6 cm
4.2 cm
86 g
Dimensions & Weight (Handset)
5.1 cm
3.2 cm
16.6 cm
94 g
Resources
The following resources are available for the BT Everyday Phone without Answer Machine - Two Handsets
Answer Machine: No
Mounting: Table-top
Big Button: No
Brand: BT
Price Range Ex VAT: 0 - 50
