The Everyday Phone Nuisance Call Blocker, gives you back control over which calls you want to take and which you want to block. The Everyday Phone can block 20 individual numbers, meaning that you really can avoid speaking to the people you don't want to. For those times when you just want some peace and quiet, switch on Block All so that your phone won't ring. If you want key friends and family to still get through, they can do, by tagging them as VIP's in your address book. Easy set up and long range reception, up to 300m outdoors, 50m indoors.
Nuisance Call Blocking
Only talk to the people you want to by blocking up to 20 numbers*.
For peace and quiet, switch on Do Not Disturb so that your phone won't ring or light up.
Easy to Use
Our BT phones have excellent sound quality with volume adjustment to suit your needs.
See whose calling before answering on the 1.5" amber display.
Freedom to move in your house
Save up to 50 contact. All these contacts are automatically copied to all of your handsets
Adjust the volume if the caller is too loud or too quiet
Box Contains
1 x Base Unit including charger
1 x Handset
Rechargeable batteries
1 x Mains power adaptor
1 x Telephone line cord
User Guide
