BT Everyday Phone with Answer Machine - Three Handsets
Quicklinx: D93GWS00 Mfr#: 090667
Type: Cordless phone
Handsets Included: 3
Answer Machine: Yes
Nuisance Call Blocker: Yes
Mounting: Table-top
Select:
Hurry, only 2 left in stock!
£49.99 ex VAT
£59.98 inc VAT
Everyday Phone with call blocking and answer machine
Nuisance Call Blocking
  • Only talk to the people you want to by blocking up to 20 numbers.
  • For peace and quiet, switch on Do Not Disturb so that your phone won't ring or light up.
Easy to Use
  • Our BT phones have excellent sound quality with volume adjustment to suit your needs.
  • See whose calling before answering on the 1.5" amber display.
Freedom to move in your house
  • Save up to 50 contact. All these contacts are automatically copied to all of your handsets
  • Adjust the volume if the caller is too loud or too quiet
*You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
  • Nuisance Call blocking features
    The Everyday Phone can block 20 individual numbers, meaning that you really can avoid speaking to the people you don't want to.
  • Do Not Disturb
    For those times when you just want some peace and quiet, switch on Block All so that your phone won't ring. If you want key friends and family to still get through, they can do, by tagging them as VIP's in your address book.
BT Everyday Phone Trio - cordless phone - answering system with caller ID + 2 additional handsets
Cordless phone answering system with caller ID + 2 additional handsets
Total Number of Wireless Handsets
3
Cordless Phone Standard
DECT\GAP
Speakerphone
Call Services
Call Waiting, Call Transfer
Display
LCD display - monochrome - Yes
Additional Handsets Qty
2
3
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID
Max Handsets Supported
5
Max Base Units Supported
4
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
300 m
Dialer Location
Handset
Conference Call Capability
Speakerphone
Volume Control
Ring Tones
5
Handset Locator
Indicators
Visual ringer light
Additional Functions
Call timer, built-in clock, Alarm, Intercom
Phone Memory
Phone Directory Capacity
50 names & numbers
Caller ID Memory
20 names & numbers
Answering System
Recording Capacity
15 min
Display
Display Location
Handset
Diagonal Size
1.6"
Backlit
Placing / Mounting
Table-top
AAA type
500 mAh
Rechargeable - Nickel Metal Hydride
Talk Time
Up to 600 min
Standby Time
Up to 100 h
Dimensions & Weight (Base)
10.4 cm
11.6 cm
4.2 cm
86 g
Dimensions & Weight (Handset)
5.1 cm
3.2 cm
16.6 cm
94 g
Resources
The following resources are available for the BT Everyday Phone with Answer Machine - Three Handsets
Answer Machine: Yes
Mounting: Table-top
Big Button: No
Brand: BT
Price Range Ex VAT: 0 - 50
