BT Essential Phone - Two Handsets
Quicklinx: D93LWS00 Mfr#: 090658
Type: Cordless phone
Handsets Included: 2
Answer Machine: Yes
Nuisance Call Blocker: Yes
Mounting: Table-top
33 In Stock
£41.66 ex VAT
£49.99 inc VAT
Express delivery Delivered on Tuesday
Essential Phone
with easy call blocking and answer machine
Stay in control of who you speak to by easily blocking nuisance calls from specific numbers and call types.
Featuring
  • Works with all landline providers
  • 1.8 inch backlit screen
  • Block up to 100 numbers1
  • Block calls from specific numbers and call types1
  • Dedicated call blocking button
  • Record up to 30 minutes of messages
  • Save up to 100 contacts
  • See who’s calling before you pick up1
  • Redial any of the last 10 calls
  • Handsfree speaker
  • Adjustable incoming speech/handsfree volume
1 You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Fed up with nuisance calls?
Call Blocking puts you back in control by allowing you to choose the calls you want to take and those you want to block. You can block specific call types, like international and withheld numbers and use the one touch call blocking button to block an incoming call or if you’ve answered a call, press to stop the number calling again. You can also store up to 100 specific numbers you don’t want calling you.
Packed with great features
An easy to set up phone with excellent sound quality. You can save up to 100 contacts to your phonebook and even set some contacts as VIP callers to ensure they will always get through when Call Blocking is on and set to Allow VIP.
Need an answering machine?
Save up to 30 minutes of messages. You can playback your messages privately through the handset or using the handsfree speaker. And don’t miss important messages when away from home with remote access to your messages.
Want to talk handsfree?
Handsfree lets you talk to your caller without holding the handset, so you’re free to get on with other things, make notes or let other people in the room listen to the conversation over the loudspeaker.
  • Nuisance Call blocking features
    Avoid nuisance and unwanted calls with the Essential Phone. Block up to 100 specific numbers or use the Dedicated Call Block Button to silence your calls.
  • Easy set up and great sound quality
    Get the most of your phone straight away with the easy to use menu and great sound.
BT Essential Phone Twin - cordless phone - answering system with caller ID + additional handset
Cordless phone answering system with caller ID + additional handset
Total Number of Wireless Handsets
2
Cordless Phone Standard
DECT\GAP
Speakerphone
Call Services
Call Waiting, Call Transfer, Call Block
Display
LCD display - monochrome - Yes
Additional Handsets Qty
1
2
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID
Max Handsets Supported
4
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
300 m
Dialer Location
Handset
Conference Call Capability
Speakerphone
Volume Control
Ring Tones
10
Handset Locator
Indicators
Visual ringer light
Additional Functions
Call timer, built-in clock, Alarm, Intercom, keyboard lock
Phone Memory
Phone Directory Capacity
100 names & numbers
Caller ID Memory
10 names & numbers
Answering System
Recording Capacity
30 min
Display
Display Location
Handset
Diagonal Size
1.8"
Backlit
Placing / Mounting
Table-top
AAA type
550 mAh
Rechargeable - Nickel Metal Hydride
Talk Time
Up to 720 min
Standby Time
Up to 120 h
Dimensions & Weight (Base)
9.2 cm
4.5 cm
12.9 cm
128.8 g
Dimensions & Weight (Handset)
5.1 cm
3.5 cm
17.8 cm
123.2 g
Resources
The following resources are available for the BT Essential Phone - Two Handsets
Answer Machine: Yes
Mounting: Table-top
Big Button: No
Brand: BT
