- Phonebook Memory: 200 name and number directory; directory copying between handsets
- Base and handset volume control
- Ringtones: 5 standard 10 polyphonic (handset only)
- Message waiting indicator
- 30 number calls list 10 Number redial list
- SMS Facility: Yes; for SMS text messaging to work you must subscribe to a caller display service not withhold your telephone number and not bar premium rate calls
- SIM Card Reader: SIM Card reader and writer
- Range From Base: Indoor range 50m Outdoor range 300m
- Number of Handsets: 1
- Answer Machine: 27 minutes recording time
- Caller ID: For any phone to show caller ID numbers your must subscribe to a caller display service - charges may apply
- Handsfree Function: yes
- Standby Time: 180hrs
- Talk Time: 12hrs
- Headset socket
- Diverse repeater compatible
- Base settings PIN protected
- BT Diverse 7450 - cordless phone - answering system with caller ID/call waiting
- Product Type
- Cordless phone answering system with caller ID/call waiting
- Cordless Phone Standard
- DECT\GAP
- Answering System
- Digital
- Intercom
- Speakerphone
- Caller ID
- Voice Mail Capability
- Call Services
- Voice Mail, Caller ID, Call Waiting, Call Transfer
- Speed Dial Capacity
- 8
- Display
- LCD display - monochrome - Yes
- Display Features
- Inverted
- Display (2nd)
- LED display - monochrome
- Body Colour
- Black
- 1 year warranty
- Product Type
- Body Colour
- Black
Phone Features
- DECT\GAP
- Call Services
- Caller ID Type
- Caller ID/call waiting
- Max Handsets Supported
- 5
- Multi-Handset Configuration
- Phonebook transfer
- Max Base Units Supported
- 4
- Max Handset Operating Distance
- 50 m
- Max Handset Operating Distance (Outdoor)
- 300 m
- Dialer Type
- Keypad
- Dialer Location
- Handset
- Conference Call Capability
- 3-way
- Intercom
- Speakerphone
- Short Messaging Service (SMS)
- Menu Operation
- Function Buttons
- Speakerphone button, recall button, intercom button, auto redial button
- Volume Control
- Ringer Control
- Ring Tones
- 15
- Polyphonic Ringer
- Handset Locator
- Indicators
- Low battery indicator, out-of-range indicator, visual ringer light
- Additional Functions
- Call timer, built-in clock, Alarm, Intercom, phonebook transfer
- Additional Features
- Out of range alert, key lock, PIN code, tone control, built-in SIM card reader
Phone Memory
- Phone Directory Capacity
- 200 names & numbers
- Dialed Calls Memory
- 10
- 8
- Caller ID Memory
- 30 names & numbers
- SMS Memory Capacity
- Up to 40 SMS
Answering System
- Answering System Type
- Digital
- Outgoing Announcements Qty
- 2
- Max Outgoing Message Length
- 60 sec
- Max Incoming Message Length
- 3 min
- Recording Capacity
- 27 min
- Memo Record Function
- Message Counter Display
- Services
- Toll Saver, Call Screening
Display
- Display Location
- Handset
- Line Qty
- 8
- Display Information
- Battery status
- Backlit
- Inverted
Display (2nd)
- LED display
- Colour Support
- Monochrome
- Display Location
- Base
- Aerial
- Internal
- Connections
- Headset jack
- Cables Included
- Phone line cable
- Included Accessories
- Belt clip, power adapter
- Power adapter - external
- Battery
- 2 x battery - AAA type
- Capacity
- 600 mAh
- Technology
- Rechargeable - Nickel Metal Hydride
- Included Qty
- 2
- Talk Time
- Up to 720 min
- Standby Time
- Up to 120 h
- Audible Battery Alert
Dimensions & Weight (Base)
- 16 cm
- 12 cm
- 7.2 cm
- 260 g
Dimensions & Weight (Handset)
- 5.3 cm
- 3.1 cm
- 16.3 cm
- 133 g
Jabra 2.5mm Jack Lead with Quick Disconnect - Straight | In Stock | £13.33 |
Jabra HHC Adapter | In Stock | £24.81 |
