Product
Brand
BT Digital Baby Monitor 300
Quicklinx: 9N50WS00 Mfr#: 077497
BT Baby Monitor 300
The BT Digital Baby Monitor 300 gives you peace of mind whilst your baby is resting or sleeping peacefully and has Hi Definition (Hi-dS) sound so every breath, gurgle and cry from your baby will come through loud and clear when they need you.
Sound level LED’s alert you visually to any sounds coming from your baby’s room. It is well specified with DECT (Digital Enhanced Cordless Telecommunications) digital technology which means there are 120 dynamic channels available.
The wireless range of the BT Digital Baby Monitor 300 lets you keep connected to your baby up to 50 metres indoors and up to 300 metres outdoors. The rechargeable parent unit is portable so you can take it with you as you walk around the house or even in the garden and an out of range alert lets you know if you are getting out of range of the transmitting unit, so you’ll never have to worry if you’re close enough to hear what’s going on.
BT Digital Baby Monitor 300 also features an ingenious two way talk back function so not only can you hear your baby if they wake, you’ll be able to let your baby hear the sound of your voice instantly and remotely from another room or communicate with a partner in the room.
The parent unit is wipe clean with rubberised keys and an adjustable nightlight will help you find your way in the nursery.
Other features on this product include mute function, crying alert, paging, low battery alert and volume control.
  • Parent unit
  • Baby unit
  • 2 x AA rechargeable batteries
  • User guide
  • Welcome card
  • Cardboard inners
  • Plastic wrapping
  • Battery pull tab
1 Year Warranty
Resources
The following resources are available for the BT Digital Baby Monitor 300
