Works with any Broadband provider
BT's Broadband Extender Flex 600 Kit has been designed to work with any service provider to make sure everyone can make the most of their Broadband at home.
What does BT’s Broadband Extender Flex 600 Kit give you?
Connect any wired device to your home broadband anywhere in your home with our powerline technology and enjoy the full broadband experience.
Plug & Play - No install necessary, just instant access to your broadband anywhere in your home!
Everyone loves to be online; and why should you settle for anything other than the complete broadband experience? With BT’s Broadband Extender Flex 600 Kit, you are able to connect any wired device wherever and whenever you like.
With up to 500 Mbps for smooth HD/3D streaming, online gaming or faster downloads, BT's Broadband Extender Flex 600 Kit supports all your online needs.
Simple to use
BT’s Broadband Extender Flex 600 Kit is easy to use. Simply plug into your wall socket and you are ready to enjoy a complete broadband experience. You also won’t lose a socket with the pass through socket included!
Make the most of your Broadband
BT's Broadband Extender Flex 600 Kit offers the solution to a number of your broadband problems. Be it connecting a Smart TV in a different room to your router, using an old laptop without Wi-Fi capability or getting the best online gaming experience possible, BT's Broadband Extender Flex 600 Kit can be used to help make the most of your Broadband at home.
Compatible with other technologies
BT's Broadband Extender Flex 600 Kit works seamlessly with all other BT Broadband Extender products to create your new home network. It is also completely compatible with other AV HomePlug powerlines so you can integrate it with any existing Powerline network. The Broadband Extender Flex 600 Kit utilises HomePlug AV500 Powerline technology and can be fully integrated with an existing AV200 network in your home.
Better for the environment
Eco credentials come as standard with built-in power saving and fully recyclable packaging.
Simple to use
BT's Broadband Extender Flex 600 Kit is easy to use. Simply plug into your wall socket and you are ready to enjoy a complete broadband experience. -
Enhance your broadband
BT's Broadband Extender Flex 600 Kit offers a solution to a number of your broadband problems. Be it connecting a Smart TV in a different room to your router, using a laptop without Wi-Fi capability or getting a good online gaming experience. -
BT's Broadband Extender Flex 600 Kit works seamlessly with all other BT Broadband Extender products to create your home network.
- BT Broadband Extender Flex 600 Kit - powerline adapter - wall-pluggable
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 600 Mbps
- Power
- AC 230V (50 Hz)
- 6.57 cm x 7.77 cm x 12.59 cm
- 200 g
- Localisation
- United Kingdom
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 600 Mbps
- Encryption Algorithm
- 128-bit AES
- Status Indicators
- Power, LAN, link/activity
- LAN: 1 x HomePlug AV - power , LAN: 1 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 2.6 watt
- Cables Included
- 2 x network cable
- Localisation
- United Kingdom
- 6.57 cm
- 7.77 cm
- 12.59 cm
- 200 g
- 0 °C
- 40 °C
- 10 - 90%
