BT Broadband Extender Flex 1000 Kit
Quicklinx: BB4XWS00 Mfr#: 080219
Type: Bridge
Speed: 1000Mbps
Connectivity: Wired
£74.99 ex VAT
£89.98 inc VAT
Express delivery Order within the next 6 hours for delivery tomorrow
Extend your existing home network with BT's Broadband Extender Flex 1000, and connect any wired device wherever and whenever you like, without losing a power socket.
Whether you're connecting the latest smart TV, using an old laptop or computer (one without a wireless adapter) in a different room from your router or want the best possible on-line gaming experience, the Broadband Extender Flex 1000 gets you on-line. Just plug it into your wall socket and you're ready to get more from your broadband.
The Broadband Extender Flex 1000 is the perfect addition to get the most of you super-fast fibre broadband.
  • Perfect for super-fast broadband.
  • Turn any power socket into an Ethernet port.
  • Up to 1000Mbps* for smooth HD and 3D streaming.
  • Pass-through socket so you can plug in other appliances.
  • Create your own Broadband Extender network with the latest AV2 technology.
  • Compatible with HomePlug AV powerline technologies.
*Maximum channel data rate. Actual speeds will vary depending on things like your set up, quality of electrical wiring and electrical interference. The data rate of the Gigabit Ethernet connections is 1000Mbps.
3 Years Warranty
Resources
The following resources are available for the BT Broadband Extender Flex 1000 Kit
Type: Bridge
Speed: 1000Mbps
Connectivity: Wired
Brand: BT
Price Range Ex VAT: 50 - 100
