BT Add-on disc for Whole Home Wi-Fi
Quicklinx: CVVTWS00 Mfr#: 091073
Select:
  • IEEE 802.11n
More than 50 in stock
£66.66 ex VAT
£79.99 inc VAT
Express delivery Order within the next 19 hours for delivery on Friday
Key Features:
  • Add this disc to your existing Whole Home Wi-Fi kit to extend coverage even further, removing Wi-Fi dead spots. You must add this to an existing Whole Home Wi-Fi set up, it will not work on its own.
  • Easy set up in minutes with step by step instructions in the Whole Home Wi-Fi app
  • View your additional disc in the app where you can see who's online and even pause the internet
  • Intelligent Wi-Fi technology automatically connects you to the fastest and strongest signal as you move from room to room (Wi-Fi roaming and band steering)
  • Works with all broadband providers, AC2600 Dual-Band wireless technology
  • Not compatible with Complete WiFi (Black Discs)
Expand your existing BT Whole Home Wi-Fi network system with this add-on disc. This additional disc will only work when added to BT's Whole Home Wi-Fi solution to further expand your superfast, super-reliable Wi-Fi network. With a mighty AC2500 wireless punch Whole Home Wi-Fi puts what matters most at your fingertips. It talks to all your gadgets to make sure they're always automatically connected to the fastest and strongest signal. And it's bristling with brilliant controls that put you in charge of a supercharged home network. This is Wi-Fi at its finest. With BT Whole Home Wi-Fi you can have your favourite TV, films, music and games in any room you wish. No more dead spots. Even when there's a laptop connected in the kitchen, smartphones upstairs and a tablet in the lounge - they all stay connected, all the time.
BT Whole Home Wi-Fi Add-on disc - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
16.5 cm x 7.7 cm x 16.5 cm
415 g
3-year warranty
Radio access point
16.5 cm
7.7 cm
16.5 cm
415 g
External
Wireless
Data Transfer Rate
1733 Mbps
Line Coding Format
256 QAM
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
WPS, starting, connection status
Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPS
IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
Aerial
Antenna
Internal
Antenna Qty
4
1 x 1000Base-T - RJ-45 (WAN)
1 x network cable
External power adapter
7.09 Watt
Limited warranty - 3 years
10 - 85%
Resources
The following resources are available for the BT Add-on disc for Whole Home Wi-Fi
Type: Radio access point
Connectivity: Wireless
Speed: 1733Mbps
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Brand: BT
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
