BT Add-on disc for Premium Whole Home Wi-Fi
Quicklinx: F7BYWS00 Mfr#: 093591
Select:
17 in stock
£99.99 ex VAT
£119.98 inc VAT
Express delivery Order within the next 21 hours for delivery on Wednesday
Expand your existing BT Premium Whole Home Wi-Fi network system with this add-on disc.
This additional disc will only work when added to BT's Premium Whole Home Wi-Fi solution to further expand your superfast, super-reliable Wi-Fi network.
Tri-band AX3700 technology gives multiple users our speediest wi-fi. So everyone can watch, stream and download at the same time. It talks to all your gadgets to make sure they're always automatically connected to the fastest and strongest signal. And it's bristling with brilliant controls that put you in charge of a supercharged home network. This is Wi-Fi at its finest. With BT Premium Whole Home Wi-Fi you can have your favorite TV, movies, music and games in any room you wish. No more dead spots. Even when there's a laptop connected in the kitchen, smartphones upstairs and a tablet in the lounge - they all stay connected, all the time.
*Premium Whole Home Wi-Fi adds a third Wi-Fi radio for "tri-band" which offers a dedicated high power connection between discs that utilises brand new 802.11ax (Wi-Fi 6) technology to deliver ultrafast speeds around the home
Restrictions - Premium Whole Home Wi-Fi can only be used in England, Wales, Scotland and Northern Ireland. As it may use frequencies in the 5.725-5.825GHz band which are not allowed elsewhere in Europe.
BT Premium Whole Home Wi-Fi Add-on disc - radio access point
Radio access point
External
IEEE 802.11ax, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
3-year warranty
Radio access point
External
Tri-band Wireless technology
IEEE 802.11ax 5GHz, 802.11a/n/ac 5GHz, 802.11b/g/n 2.4GHz
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
WPS, starting, connection status
Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPS
IEEE 802.11ax, IEEE 802.11ac, IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
Aerial
Antenna
Internal
Antenna Qty
6
1 x 1000Base-T - RJ-45 (WAN)
1 x network cable
External power adapter
Limited warranty - 3 years
10 - 85%
Type: Premium Whole Home Wi-Fi
Connectivity: Tri-band Wireless Technology
Protocol: 802.11a/n/ac 5GHz
Protocol: 802.11b/g/n 2.4GHz
Protocol: IEEE 802.11ax 5GHz
Antennas: 6
Brand: BT
Price Range Ex VAT: 50 - 100
