BT 2700 Nuisance Call Blocker - Single
Quicklinx: C9S6WS00 Mfr#: 086905
Select:
  • Single
BT 2700 Cordless DECT Phone with Nuisance Call Blocker
Key Features
  • Avoid nuisance and unwanted calls with our new BT 2700*
  • Block up to 50 specific numbers or use Do Not Disturb to silence your calls
  • Get the most our of your phone straight away with our easy to use menu and great sound
  • BT 2700 is available in single, twin, trio or quad handset pack sizes
Detailed Features
  • Built in Digital Answer Machine
  • Block up to 50 numbers*
  • Excellent sounds quality
  • Easy set up
  • Handsfree speaker
  • Long range reception, up to 300m outdoors, 50m indoors
  • Up to 12 hours of talking, 120 hours on standby
  • See and hear if you have a second call waiting
  • Easy to read screen shows when you have messages
  • Do Not Disturb mode
  • Save up to 50 contacts
  • Backlit screen
  • Redial any of the last 10 calls you made
  • 1.6 inch backlit screen
*You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Resources
The following resources are available for the BT 2700 Nuisance Call Blocker - Single
