BT 2200 Twin
BT 2200 Twin
Quicklinx: C9S4WS00 Mfr#: 086902
Select:
  • Twin
BT 2200 Cordless DECT Phone with Nuisance Call Blocker
Key Features
  • Avoid nuisance and unwanted calls with the BT 2200
  • Block up to 50 specific numbers or use Do Not Disturb to silence your calls
  • Get the most out of your phone straight away with our easy to use menu and great sound
  • BT 2200 is available in single, twin or trio handset pack sizes
Detailed Features
  • Block up to 50 numbers
  • Excellent sounds quality
  • Easy set up
  • Handsfree speaker
  • Long range reception, up to 300m outdoors, 50m indoors
  • Up to 12 hours of talking, 120 hours on standby
  • See and hear if you have a second call waiting
  • Easy to read screen shows when you have messages
  • Do Not Disturb mode
  • Save up to 50 contacts
  • Backlit screen
  • Redial any of the last 10 calls you made
  • 1.6 inch backlit screen
Resources
The following resources are available for the BT 2200 Twin
