Brother TD-4000 Thermal Desktop Label Printer
Quicklinx: 8CRQWS00 Mfr#: TD4000ZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
£320.18 ex VAT
£384.21 inc VAT
Labels often have to incorporate a considerable amount of important information, so you need a printer that can put it all together efficiently and with consistently high-quality results.
The TD-4000 prints at up to 110mm per second and 300dpi, with a built-in automatic cutter. Your labels can be up to 102mm wide, and anywhere from 25mm to 3m long.
The TD-4000's P-Touch Editor software supports barcode printing, and also allows you to import graphics and date for a truly personalised solution – so this feature-packed professional label printer always delivers.
  • An easy integration solution for software developers
    Brother provides an easy-to-use software development kit for integrating the TD-4000 desktop barcode and label printers into most Windows applications. Using the Brother API, applications can pass text, numbers, graphics, and bar code data to document templates, and print labels, receipts, and tags directly to the printers. This simplifies printer integration and frees application developers from having to use the Windows API.
Brother TD-4000 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.8 kg
Max Media Size
Roll A6 (10.5 cm)
Min Media Size (Custom)
19 mm
Max Media Size (Custom)
105 mm
Max Resolution (B&W)
300 dpi
USB, serial
RAM Installed (Max)
2 MB
Language Simulation
EPSON ESC/P
Barcodes
Code 39, UCC/EAN-128, NW-7, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, PDF417, Data Matrix, ITF, GS1 DataBar Omnidirectional, GS1 DataBar Expanded, GS1 DataBar Limited
Media Type
Continuous paper labels, die cut labels
Fonts
Brussels, Helsinki, San Diego, Letter Gothic, Letter Gothic Bold
Character Sizes
24 points, 48 points, 32 points
Styles & Effects
Bold, outline shadow, vertical, outline, shadow, italic, underline
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
1-year warranty
17.3 cm x 22.9 cm x 15.8 cm
Printer Type
Printer
Built-in Devices
Cutter
Wired
USB, serial
300 dpi
Language Simulation
EPSON ESC/P
Fonts
Character Sizes
Styles & Effects
Auto Cutter
Barcodes
RAM
RAM Installed (Max)
2 MB
Media Handling
Media Type
Max Media Size
Roll A6 (10.5 cm)
19 mm
105 mm
Max Printing Width
98.6 mm
Media Thickness Range
0.08 mm - 0.17 mm
Roll Maximum Outer Diameter
102 mm
Roll Core Diameter
25.4 mm
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
Power supply - internal
Software Included
Brother P-touch Editor 5
Limited warranty - 1 year
10 °C
35 °C
20 - 80%
17.3 cm
22.9 cm
15.8 cm
1.8 kg
Type: Printer
Max Paper Size: Roll A6 (10.5 cm)
Brand: Brother
Price Range Ex VAT: 300 - 500
