Brother RJ-4030 Rugged Bluetooth Mobile Printer
Quicklinx: 9FXMWS00 Mfr#: RJ4030Z1
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Laser
10 in stock
£414.70 ex VAT
£497.64 inc VAT
The rechargeable RJ-4030 is an extra tough, super-fast printing solution designed with busy field workers in mind.
Print up to 4" receipts, quotes, invoices and labels for customers on the spot, saving you and your customers' valuable time.
Serial, Bluetooth and USB connectivity capabilities which mean it's easy to integrate into your existing systems are housed in a rugged design that can withstand all the demands of your workplace, including harsh outdoor conditions. And the thermal print technology means you'll never have to worry about ink or toner.
The RJ-4030 has achieved an IP54 drop test rating and is totally dust and waterproof. We also offer a range of add-on accessories which means this on-person printer provides you with ultimate flexibility.
  • Fast print speed of up to 5 ips
    Faster transactions can mean less wasted time, higher productivity, and increased customer satisfaction.
  • Tough construction
    IP54 certification and 6 feet drop protection mean that water, dust, or drops won't affect the printer's operation under normal conditions.
  • Versatile functionality
    Prints on labels and receipts from 2 inches wide to 4 inches wide - one mobile printer can be used for different mobile applications.
  • Ergonomic design
    Easy to load media and intuitive interface controls.
  • Low maintenance costs
    Highly reliable direct thermal technology uses fewer moving parts than other printing technologies. Fewer moving parts mean fewer parts to fail.
  • Low consumable costs
    There is no ink or ribbons to replace. The only consumable is the media.
  • Higher memory capacity
    It offers larger print buffer for increased throughput and more memory to store optional fonts.
  • 203 dpi resolution
    It ensures compatibility with existing mobile applications.
  • Wide selection of resident and downloadable fonts
    Enhance your output with Brother's wide selection of fonts.
  • Supports for the major linear and 2D barcodes
    Ensures compatibility with existing applications and provides the technology for more applications.
  • Fanfold media capability
    External media slot in the back of the printer for warehousing applications.
Brother RuggedJet RJ-4030 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
Portable
850 g
Max Media Size
Roll (11.8 cm)
Print Speed
Up to 127 mm/sec
Max Resolution (B&W)
203 dpi
USB, serial, Bluetooth
RAM Installed (Max)
32 MB
Flash Memory Installed (Max)
16 MB
Language Simulation
EPSON ESC/P, EPSON ESC/P Raster
Barcodes
Code 39, UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, OCR-A, OCR-B, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded, GS1 DataBar Expanded Stacked, GS1 DataBar Limited, GS1 DataBar Stacked
Media Type
Receipt labels, die cut labels
Fonts
Helsinki, Letter Gothic, Letter Gothic Bold
Print server - Bluetooth 2.0 EDR
Required 1 Lithium Ion
Microsoft Windows Vista / XP / 7
16.2 cm x 7.7 cm x 17.6 cm
Printer Type
Printer
Print Speed
Up to 127 mm/sec
Wireless
203 dpi
Language Simulation
Fonts
Barcodes
RAM
RAM Installed (Max)
32 MB
Flash Memory
Flash Memory
16 MB
Media Handling
Media Type
Max Media Size
Roll (11.8 cm)
Media Sizes
Roll (5.1cm), Roll (11.8 cm)
Max Printing Width
104 mm
Max Printing Length
3000 mm
Roll Maximum Outer Diameter
58 mm
Roll Core Diameter
25.4 mm, 12.7 mm
Media Feeders
1 x manual - 1 roll - Roll (11.8 cm)
Print server
Bluetooth 2.0 EDR
Bluetooth 2.0
1 x serial , 1 x USB - 4 pin mini-USB Type B
IP54
Lithium Ion
Required Qty
1
Run Time (Up To)
2000 pages
Software Included
Drivers & Utilities, Brother P-touch Editor 5, Brother P-touch Transfer Manager 2.1
20 - 80% (non-condensing)
16.2 cm
7.7 cm
17.6 cm
850 g
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: Roll (11.8 cm)
Brand: Brother
Price Range Ex VAT: 300 - 500
