Brother QL-820NWB Network Label Printer
Quicklinx: D4R3WS00 Mfr#: QL820NWBZU1
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: Roll (6.2 cm)
  • Windows 8 (32/64 bits)
Hurry, only 2 left in stock!
£121.41 ex VAT
£145.69 inc VAT
The flexible label printer which integrates with your connectivity requirements
Print labels from your PC, Mac, smartphone or tablet using USB, Ethernet, Wi-Fi and Bluetooth. Or alternatively use it in standalone mode by selecting and printing labels previously designed and uploaded to the memory, using the integrated backlit LCD display. When used with special rolls, you can print labels that can contain both black and red print without needing any ink. And when you can print custom sized labels up to one metre in length using the built-in cutter and continuous rolls, you can see why this is the most advanced label printer available.
Key Features
  • USB, Ethernet, Wi-Fi and Bluetooth connectivity with support for MFi and AirPrint
  • Print on pre sized labels (for your address shipping labels) or continuous rolls up to 62mm wide (for indoor/outdoor signage). Or print labels stored in memory using the integrated control panel.
  • Large backlit LCD display for easy set-up and operation
  • Print in black and red without needing ink or toner
  • Built-in cutter to create your own length labels
  • Optional rechargeable Li-ion battery base for mobile labelling applications
Brother QL-820NWB - label printer - two-colour (monochrome) - direct thermal
Printer Type
Label printer - direct thermal - two-colour (monochrome)
1.16 kg
Ireland
Max Media Size
Roll (6.2 cm)
Max Media Size (Custom)
62 mm
Print Speed
Up to 110 labels/min , Up to 176 mm/sec
Max Resolution (B&W)
300 x 600 dpi
USB 2.0, LAN, Wi-Fi(n), USB host, Bluetooth 2.1 EDR
AirPrint Enabled
Barcodes
Code 93, Code 39, GS1 DataBar, QR code, MaxiCode, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Postnet, PDF417, Data Matrix, ITF, Micro QR code, EAN-8, EAN-13, GS1-128
Media Type
Die cut labels, label continuous paper
Compatible Tapes
DK tape
Fonts
Brussels, Helsinki, Letter Gothic
Styles & Effects
Bold, normal, vertical, shadow, italic, shadow light, surround, horizontal lines, invert
Printer Features
Auto Power Off
AC 120/230 V
Required 1 Lithium Ion Included Qty 0
Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.10.x, Windows 10 (32/64 bits), Apple MacOS X 10.11.x, Apple MacOS 10.12.x
Enclosure Colour
White, glossy black
1-year warranty
12.53 cm x 23.4 cm x 14.5 cm
Printer Type
Enclosure Colour
White, glossy black
Ireland
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
300 x 600 dpi
Fonts
Styles & Effects
Auto Cutter
Barcodes
Printer Features
Auto Power Off
Media Handling
Media Type
Compatible Tapes
DK tape
Max Media Size
Roll (6.2 cm)
62 mm
Media Sizes
Roll (6.2 cm)
Max Printing Width
58 mm
Media Feeders
1 x manual - 1 roll - Roll (6.2 cm)
1 x USB 2.0 , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
1 x USB cable
Media Included
62 mm x 5 m black/red paper tape, 29 x 90 mm black on white standart address labels (100 labels)
MFI
Power adapter - external
AC 120/230 V
Frequency Required
50/60 Hz
Lithium Ion
Required Qty
1
Included
0
Software Included
Software Development Kit (SDK)
Limited warranty - 1 year
10 °C
35 °C
20 - 80%
12.53 cm
23.4 cm
14.5 cm
1.16 kg
Type: Printer
Wireless Capability: Wireless
Brand: Brother
Price Range Ex VAT: 100 - 150
