Your whole workgroup can now print labels wirelessly with the QL-710W and enjoy a whole lot more flexibility as a result.
Everyone in your network can produce consistently great-looking results whenever, wherever – whether you're in need of CD labels, barcode labels, or anything else in between. You can even print directly from MS Word, Excel and Outlook, or your Apple or Android devices via the iPrint and Label app.
And with the capacity to print up to 93 labels a minute, a built-in automatic cutter and print quality up to 600dpi, the QL-710W offers all the speed and convenience you could need.
- Brother QL-710W - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.2 kg
- Max Media Size
- Roll (6.2 cm)
- Max Media Size (Custom)
- 62 mm
- Print Speed
- Up to 93 labels/min , Up to 150 mm/sec
- Max Resolution (B&W)
- 300 x 720 dpi
- Cutter
- Interface
- USB, Wi-Fi(n)
- Barcodes
- Code 39, UCC/EAN-128, ISBN, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Postnet, PDF417, Data Matrix, ITF
- Media Type
- Envelopes, labels, address labels, file folder labels, CD/DVD labels, shipping labels, die cut labels
- Compatible Tapes
- DK tape
- Styles & Effects
- Vertical, Mirror, rotated text
- Networking
- Print server - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008, Apple MacOS X 10.5.8 - 10.7
- 3-year warranty
- 12.8 cm x 23.6 cm x 15.3 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- USB, Wi-Fi(n)
- 300 x 720 dpi
- Styles & Effects
- Auto Cutter
- Repeating Printing
- 9999 copies
- Barcodes
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Max Media Size
- Roll (6.2 cm)
- 62 mm
- Media Sizes
- Roll (6.2 cm)
- Max Printing Width
- 58.4 mm
- Max Printing Length
- 914 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (6.2 cm)
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x USB - 4 pin USB Type B
- Cables Included
- 1 x USB cable
- Media Included
- 1 62 mm x 8 m label tape cassette, 1 roll of 100 address labels
- Power Device
- Power supply - internal
- Software Included
- Drivers & Utilities, P-touch Address Book 1.1 for Windows, P-touch Editor 5.0 for Mac OS, P-touch Editor 5.0 for Windows
- OS Required
- Limited warranty - 3 years - carry-in
- 12.8 cm
- 23.6 cm
- 15.3 cm
- 1.2 kg
