Your basket is empty
Brother QL-710W Professional Address Label Printer with Wireless
Quicklinx: 8CRHWS00 Mfr#: QL710WZU1
Your whole workgroup can now print labels wirelessly with the QL-710W and enjoy a whole lot more flexibility as a result.
Everyone in your network can produce consistently great-looking results whenever, wherever – whether you're in need of CD labels, barcode labels, or anything else in between. You can even print directly from MS Word, Excel and Outlook, or your Apple or Android devices via the iPrint and Label app.
And with the capacity to print up to 93 labels a minute, a built-in automatic cutter and print quality up to 600dpi, the QL-710W offers all the speed and convenience you could need.
Brother QL-710W - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.2 kg
Max Media Size
Roll (6.2 cm)
Max Media Size (Custom)
62 mm
Print Speed
Up to 93 labels/min , Up to 150 mm/sec
Max Resolution (B&W)
300 x 720 dpi
USB, Wi-Fi(n)
Barcodes
Code 39, UCC/EAN-128, ISBN, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Postnet, PDF417, Data Matrix, ITF
Media Type
Envelopes, labels, address labels, file folder labels, CD/DVD labels, shipping labels, die cut labels
Compatible Tapes
DK tape
Styles & Effects
Vertical, Mirror, rotated text
Print server - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008, Apple MacOS X 10.5.8 - 10.7
3 years warranty
12.8 cm x 23.6 cm x 15.3 cm
Printer Type
Printer
Print Speed
Built-in Devices
Cutter
Wireless
USB, Wi-Fi(n)
300 x 720 dpi
Styles & Effects
Auto Cutter
Repeating Printing
9999 copies
Barcodes
Media Handling
Media Type
Compatible Tapes
DK tape
Max Media Size
Roll (6.2 cm)
62 mm
Media Sizes
Roll (6.2 cm)
Max Printing Width
58.4 mm
Max Printing Length
914 mm
Media Feeders
1 x manual - 1 roll - Roll (6.2 cm)
Print server
1 x USB - 4 pin USB Type B
1 x USB cable
Media Included
1 62 mm x 8 m label tape cassette, 1 roll of 100 address labels
Power supply - internal
Software Included
Drivers & Utilities, P-touch Address Book 1.1 for Windows, P-touch Editor 5.0 for Mac OS, P-touch Editor 5.0 for Windows
Limited warranty - 3 years - carry-in
12.8 cm
23.6 cm
15.3 cm
1.2 kg
