The QL-1060N delivers the best of both worlds – proven, practical label printing with all the increased productivity benefits of wired network connectivity.
Print from any computer in your network to one centralised label printer, where the up to 300dpi print resolution reproduces logos and barcodes perfectly in sizes from 12mm to a massive 102mm wide. And with printing speeds of up to 69 labels per minute and a built-in heavy-duty automatic cutter, high volumes are no problem.
Offering consistent, professional labelling, the QL-1060N makes all the right business connections.
- Brother QL-1060N - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.7 kg
- Max Media Size
- Roll (10.2cm)
- Min Media Size (Custom)
- 12 mm
- Max Media Size (Custom)
- 102 mm
- Print Speed
- Up to 110 mm/sec , Up to 69 labels/min
- Max Resolution (B&W)
- 300 dpi
- Cutter
- Interface
- USB, LAN, serial
- RAM Installed (Max)
- 4 MB
- Language Simulation
- EPSON ESC/P, EPSON ESC/P Raster
- Barcodes
- Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF
- Media Type
- Labels, continuous forms, removable labels
- Compatible Tapes
- DK tape
- Fonts
- Brussels, Helsinki, San Diego, Letter Gothic, Letter Gothic Bold
- Character Sizes
- 24 points, 48 points, 32 points
- Styles & Effects
- Bold, outline shadow, solid, vertical, outline, shadow, italic, underline
- Networking
- Print server - Ethernet, Fast Ethernet - external
- System Requirements
- Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Vista, Apple MacOS X 10.3.9 - 10.4.10
- Microsoft Certification
- Works with Windows Vista
- 3-year warranty
- 17 cm x 22 cm x 14.8 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Built-in Devices
- Cutter
- Connectivity Technology
- Wired
- Interface
- USB, LAN, serial
- 300 dpi
- Fonts
- Character Sizes
- Styles & Effects
- Auto Cutter
- Barcodes
RAM
- 4 MB
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Max Media Size
- Roll (10.2cm)
- 12 mm
- 102 mm
- Media Sizes
- Roll (1.2 cm), Roll (10.2cm), Roll (6.2 cm)
- Max Printing Width
- 98.6 mm
- Networking
- Print server - external
- Data Link Protocol
- Connections
- 1 x USB - 4 pin USB Type B , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x LAN - RJ-45
- Cables Included
- 1 x USB cable
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Device
- Power supply - internal
- Software Included
- Drivers & Utilities, Brother P-touch Quick Editor, Brother P-touch Editor V4.0
- OS Required
- Additional Requirements
- CD-ROM
- System Requirements Details
- MacOS X 10.3.9 - 10.4.10 - PowerPC HD 100 MB , Windows 2000 Pro - HD 70 MB , Windows XP - HD 70 MB , Windows Vista - HD 70 MB , Windows Server 2003 - HD 70 MB
- Limited warranty - 3 years - carry-in
- 17 cm
- 22 cm
- 14.8 cm
- 1.7 kg
