Label printers now need to be more versatile and robust than ever to keep up with businesses like yours – and the QL-1050 is more than capable.
Offering high quality labels in sizes from 12mm up to a massive 102mm wide, the 300dpi resolution is perfect for consistent barcode and logo reproduction. And with printing speeds of up to 69 labels per minute and a built-in heavy-duty automatic cutter, high volumes are no problem.
USB and RS-232 serial ports allow you to simply connect this versatile machine with any relevant equipment, and you can print directly from MS Word, Excel and Outlook.
With durability built in, the QL-1050 is a truly dependable solution.
- Brother QL-1050 - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.7 kg
- Localisation
- United Kingdom
- Max Media Size
- Roll (10.2cm)
- Max Media Size (Custom)
- 102 mm
- Print Speed
- Up to 69 labels/min , Up to 110 mm/sec
- Max Resolution (B&W)
- 300 dpi
- Cutter
- Interface
- USB, serial
- Language Simulation
- EPSON ESC/P, EPSON ESC/P Raster
- Barcodes
- Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, ITF, Micro QR code
- Media Type
- Labels, continuous forms
- Compatible Tapes
- DK tape
- Fonts
- Brussels, Helsinki, San Diego, Letter Gothic
- Character Sizes
- 24 points, 48 points, 32 points
- Styles & Effects
- Bold, italic bold, italic outline, normal, vertical, outline, shadow, italic, Mirror, underline, rotated text, frame, shadow light, surround
- System Requirements
- Microsoft Windows 2000 Professional, Microsoft Windows XP, Apple MacOS X 10.1, Apple MacOS X on Intel 10.4.4 or later, Apple MacOS X Server 10.4.7
- Microsoft Certification
- Works with Windows Vista
- 17 cm x 22 cm x 14.8 cm
- Printer Type
- Label printer - direct thermal - monochrome
- Localisation
- United Kingdom
Printer
- Print Speed
- Built-in Devices
- Cutter
- Connectivity Technology
- Wired
- Interface
- USB, serial
- 300 dpi
- Fonts
- Character Sizes
- Styles & Effects
- Auto Cutter
- Repeating Printing
- 500 copies
- Fonts Included
- 1 x TrueType
- Barcodes
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Max Media Size
- Roll (10.2cm)
- 102 mm
- Media Sizes
- Roll (2.9 cm), Roll (1.2 cm), Roll (10.2cm), Roll (6.2 cm)
- Max Printing Width
- 98.6 mm
- Connections
- 1 x USB - 4 pin USB Type B , 1 x RS-232 - 9 pin D-Sub (DB-9)
- Cables Included
- 1 x USB cable
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Device
- Power supply - internal
- Software Included
- Drivers & Utilities, Brother P-touch Editor
- OS Required
- System Requirements Details
- Windows 2000/XP - RAM 128 MB - HD 70 MB , MacOS X 10.1 or later - RAM 64 MB - HD 100 MB
- 10 °C
- 35 °C
- 20 - 80%
- 17 cm
- 22 cm
- 14.8 cm
- 1.7 kg
Ink (8)
Brother CD/DVD 100 x 58mm Labels | In Stock | £13.21 |
Brother Large Address Labels | In Stock | £8.22 |
Brother DK Continuous White Labels | In Stock | £12.96 |
Brother Shipping 62 x 100mm 300 Labels | In Stock | £11.24 |
Brother P-TOUCH Yellow Paper- 62mm | In Stock | £13.48 |
Brother p-touch White Paper - 62mm | In Stock | £12.32 |
Brother Paper Roll (6.2 cm x 30.5 m) | In Stock | £11.10 |
Brother Non Adhesive Paper Tape 54mm | In Stock | £11.69 |
Other bundles (2)
Brother BROTHER DK-22212 TAPE 62MM WH. | In Stock | £33.37 |
Brother P-TOUCH TAPE PAPER 29MMX30.48M | In Stock | £6.42 |
