Brother PTD600VP 24mm Desktop Label Printer
USE STAND-ALONE, OR CONNECTED TO A PC OR MAC!
Quicklinx: B1J9WS00 Mfr#: PTD600VPZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Thermal transfer
Hurry, only 2 left in stock!
£76.30 ex VAT
£91.56 inc VAT
The PT-D600VP is ideal for clear and durable workplace labelling up to 24 mm wide.  It is perfect for organisation of workspaces, clear identification of equipment, assets and filing, as well as creation of basic instructional or warning notices. The compact and sleek new design ensures that it fits at any office workstation.  It has a multitude of great benefits that help make the workplace more efficient and eliminate those little irritations that have staff tearing their hair out.
  • Full-color graphical display
    You can view label appearance before printing.
  • PC-connectable
    You can use stand-alone, or connected to a PC or Mac for added design capabilities.
  • Split-back tapes
    It uses durable, easy-peel tapes in 5 different widths up to 24mm (approx. 1").
  • Supports large character printing
    You can print up to 8 font sizes.
  • Multi-line labels
    It prints labels with up to 7 lines of text.
  • Personalize labels
    It uses 14 fonts, 11 styles, 99 frames, over 600 symbols, plus barcodes.
  • Large memory
    Save up to 99 commonly used labels and help save time with reprinting.
  • Specialty templates
    Print labels for asset management, cable labeling - even add time and date.
  • High-resolution PC-printing
    It is used for crisp graphic, barcode, and logo printing.
  • Super-fast print speeds
    You can print fast with Automatic Tape Cutter for high-volume jobs.
Brother P-Touch PT-D600VP - labelmaker - B/W - thermal transfer
Printer Type
Labelmaker - thermal transfer - B/W
950 g
Max Media Size
Roll (2.4 cm)
Max Media Size (Custom)
24 mm
Print Speed
Up to 30 mm/sec
USB
Media Type
Laminated tape
Compatible Tapes
TZe tape
Fonts
14 fonts
Styles & Effects
Vertical, underline
7 line printing
Display Resolution
3 lines x 20 characters / 320 x 120
Required 6 x AA type Alkaline Included Qty 0
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.7 - 10.9
Enclosure Colour
20.1 cm x 19.2 cm x 8.6 cm
Printer Type
Labelmaker - thermal transfer - monochrome
Enclosure Colour
Printer
Print Speed
Up to 30 mm/sec
Built-in Devices
Preview screen, character keyboard, cutter
USB
Fonts
14 fonts
Styles & Effects
Vertical, underline
7 line printing
Display Resolution
Auto Cutter
Media Handling
Media Type
Laminated tape
Compatible Tapes
TZe tape
Max Media Size
Roll (2.4 cm)
24 mm
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Max Printing Width
18 mm
Media Feeders
1 x manual - 1 roll - Roll (2.4 cm)
1 x USB
Carrying case
1 x USB cable
Media Included
1 24 mm x 4 m black on white TZe laminated tape cassette
Power adapter
AA type - Alkaline
Required Qty
6
Included
0
10 °C
35 °C
20 - 80% (non-condensing)
20.1 cm
19.2 cm
8.6 cm
950 g
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (2.4 cm)
Brand: Brother
Price Range Ex VAT: 50 - 100
