Brother PTD450VP 18mm Desktop Label Printer
Quicklinx: B1J8WS00 Mfr#: PTD450VPZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Thermal transfer
12 in stock
£55.21 ex VAT
£66.25 inc VAT
From file dividers to cabinets, office equipment to name badges, having everything clearly labelled is a sure-fire way to get your workplace organised and running smoothly.
With the PT-D450VP, you can quickly generate labels up to 18mm wide, either using the printer's own PC-style 'QWERTY' keyboard and high resolution backlit display to create them direct or sending your designs via your PC. It also comes complete with its own handy carry case, 18mm black on white label tape and adapter.
  • PC-connectable
    Use stand-alone, or connected to a PC or Mac for added design capabilities.
  • Split-back tapes
    Uses durable, easy-peel tapes in 4 different widths up to 18mm (approx. ¾").
  • One-touch keys
    Easily add frames and other formatting features.
  • Large memory
    Save up to 50 commonly used labels and help save time with reprinting.
  • Specialty templates
    Print labels for asset management, cable labeling and more.
Brother P-Touch PT-D450VP - labelmaker - monochrome - thermal transfer
Printer Type
Labelmaker - thermal transfer - monochrome
740 g
Max Media Size
Roll (1.8 cm)
Max Media Size (Custom)
18 mm
Print Speed
Up to 20 mm/sec
USB
Media Type
Laminated tape
Compatible Tapes
TZe tape
Fonts
14 fonts
Styles & Effects
Vertical, underline
5 line printing
Display Resolution
320 x 120
Keyboard
QWERTY / 65 keys
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.8.x, Windows 8.1, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
Enclosure Colour
18.8 cm x 17.7 cm x 7.2 cm
Printer Type
Enclosure Colour
Printer
Print Speed
Up to 20 mm/sec
Built-in Devices
Preview screen, character keyboard
USB
Fonts
14 fonts
Styles & Effects
Vertical, underline
5 line printing
Display Resolution
320 x 120
Auto Cutter
Keyboard
QWERTY / 65 keys
Repeating Printing
5000 copies
Media Handling
Media Type
Laminated tape
Compatible Tapes
TZe tape
Max Media Size
Roll (1.8 cm)
18 mm
Media Sizes
Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Max Printing Width
15.8 mm
Media Feeders
1 x manual - 1 roll - Roll (1.8 cm)
1 x USB
Carrying case
1 x USB cable
Media Included
1 18 mm x 4 m black on white TZe laminated tape cassette
Power adapter
System Requirements Details
Windows Vista/7/8/8.1 - RAM 512 MB - HD 70 MB , MacOS - RAM 2 GB - HD 500 MB
10 °C
35 °C
20 - 80% (non-condensing)
18.8 cm
17.7 cm
7.2 cm
740 g
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (1.8 cm)
Brand: Brother
Price Range Ex VAT: 50 - 100
