Keep all of your on-the-road business running smoothly with the PJ-663.
There's no need to compromise on size and quality when you're printing on the move, as this compact and durable printer quickly produces professional-looking A4 documents that always do you credit.
Bluetooth, IrDA and USB connections allow you to easily link the PJ-663 to smartphones, tablets and laptops, and our range of accessories, software and template options mean creating a tailored printing solution couldn't be easier.
Plus, as thermal technology is less susceptible to changing temperatures and humidity, this flexible printing solution is always ready to go.
- Brother PocketJet 6 PJ-663 - printer - B/W - direct thermal
- Printer Type
- Personal printer - direct thermal - B/W
- Form Factor
- Portable
- 473 g
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 6 ppm - B/W
- Max Resolution (B&W)
- 300 dpi
- Interface
- USB, Bluetooth, IrDA
- Media Type
- Thermal paper
- Networking
- Print server - Bluetooth 2.0 EDR
- System Requirements
- Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- 1-year warranty
- 25.5 cm x 5.5 cm x 3 cm
- Printer Type
- Personal printer - direct thermal - monochrome
Printer
- Print Speed
- Up to 6 ppm - B/W
- Connectivity Technology
- Wireless
- Interface
- 300 dpi
Media Handling
- Media Type
- Thermal paper
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm)
- Media Feeders
- 1 x manual - 1 sheet
- Networking
- Print server
- Data Link Protocol
- Bluetooth 2.0 EDR
- Connections
- 1 x IrDA - IrDA , 1 x USB - 4 pin USB Type B
- Included Accessories
- Cleaning kit
- Cables Included
- 1 x USB cable
- Software Included
- Brother P-touch Editor 5
- OS Required
- Limited warranty - 1 year
- 25.5 cm
- 5.5 cm
- 3 cm
- 473 g
