Take the durable PJ-622 along with you when you're out on the road and you'll never have to keep your clients or customers waiting for those all-important documents.
With USB and IrDA interfaces for seamless connectivity, this compact and convenient printer helps you work more productively whether you need to print out invoices, contracts or service reports.
Perfectly sized for your briefcase or computer bag, the PJ-622 can also be easily mounted in your vehicle. And the direct thermal printing technology ensures reliable results, whatever the conditions or environment – and no risk of running out of ink at a vital moment.
- Brother PocketJet 6 PJ-622 - printer - B/W - direct thermal
- Printer Type
- Personal printer - direct thermal - B/W
- Form Factor
- Portable
- 473 g
- Media Size Class
- A4
- Max Media Size
- Roll A4
- Print Speed
- Up to 6 ppm - B/W
- Max Resolution (B&W)
- 203 x 200 dpi
- Interface
- USB, IrDA
- Media Type
- Thermal paper
- System Requirements
- Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- 1-year warranty
- 25.5 cm x 5.5 cm x 3 cm
- Printer Type
- Personal printer - direct thermal - monochrome
Printer
- Print Speed
- Up to 6 ppm - B/W
- Connectivity Technology
- Wireless
- Interface
- USB, IrDA
- 203 x 200 dpi
Media Handling
- Media Type
- Thermal paper
- Media Size Class
- A4
- Max Media Size
- Roll A4
- Media Sizes
- Roll A4
- Media Feeders
- 1 x manual
- Connections
- 1 x IrDA - IrDA , 1 x USB - 4 pin USB Type B
- Included Accessories
- Cleaning kit
- Cables Included
- 1 x USB cable
- Software Included
- Brother P-touch Editor 5
- OS Required
- Limited warranty - 1 year
- 25.5 cm
- 5.5 cm
- 3 cm
- 473 g
