Brother PJ-763MFI A4 Thermal Mobile Printer
Quicklinx: C35KWS00 Mfr#: PJ763MFIZ1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired, Wireless
Technology: Thermal Ink-jet
More than 50 in stock
£502.13 ex VAT
£602.55 inc VAT
Print quotations, invoices, and other reports whilst on the move and streamline the work of field sales, field service, logistics, delivery and the emergency service sectors. The PJ-763MFi with built-in Bluetooth and USB connectivity offers a mobile A4 print solution compact enough to fit easily into a briefcase or computer bag, but that can also be permanently installed in vehicles. This model offers an easy method to connect to Apple iOS devices, thanks to the MFi Bluetooth protocol. High-resolution thermal print technology at 300dpi produces crisp text at a print speed of up to 8 pages per minute. Compatible with a wide range of mobile and desktop operating systems, the PJ-763MFi can easily be integrated into your own apps and software using the various SDK's (Software Development Kits) available.
High quality A4 printing on the move
The Brother PJ range of mobile printers finally offer businesses a reliable way of producing high quality A4 sized prints wherever and whenever they are required. Featuring direct thermal printing, this technology is considered by many to be the only reliable solution for mobile print applications. And as no ink, toner or ribbons are used, this ensures workers don't have to source expensive replacements when they run out - the only consumable used is the paper itself.
Compact and lightweight
Despite its incredibly small size and lightweight design, the development and manufacturing process has been focussed on producing a durable, professional printer that can be carried in a briefcase or computer bag, or permanently mounted in a vehicle.
Integrate printing within your existing mobile apps and software
Enabling printing within existing apps or software used to be a difficult task. However, as well as standard printer drivers for Windows®, Mac and Linux, Brother has a range of SDK (Software Development Kits) that allow developers to easily add printing capabilities into existing solutions, or allow new printing apps to be developed quickly and efficiently. SDK's are available for iOS, Android and Windows® operating systems.
USB connectivity
Offering the reliability of a wired connection, you can connect to Windows®, Mac or Linux based desktops and laptops, or to Android devices that have USB Host support (requires Android OS ver 3.1 or later).
Brother PocketJet PJ-763MFi - printer - monochrome - direct thermal
Printer Type
Personal printer - direct thermal - monochrome
Portable
480 g
Media Size Class
A4
Max Media Size
216 x 5490 mm
Min Media Size (Custom)
105 mm x 25.4 mm
Max Media Size (Custom)
216 mm x 5490 mm
Print Speed
Up to 8 ppm - B/W
Max Resolution (B&W)
300 x 300 dpi
USB 2.0, Bluetooth 2.1 EDR
RAM Installed (Max)
32 MB
Flash Memory Installed (Max)
6 MB
Language Simulation
EPSON ESC/P, EPSON ESC/P Raster
Barcodes
Code 93, Industrial 2 of 5, Code 39, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, MicroPDF417, Code 128, Postnet, PDF417, Data Matrix, ITF, Micro QR code, EAN-8, EAN-13, MSI, GS1-128
Media Type
Thermal paper
Print server
Linux, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Android 2.3 or later, Apple MacOS X 10.8, Apple iOS 5.0 or later, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10
Microsoft Certification
Compatible with Windows 7
3-year warranty
25.5 cm x 5.5 cm x 3 cm
Printer Type
Printer
Print Speed
Up to 8 ppm - B/W
Wireless
300 x 300 dpi
Language Simulation
Barcodes
RAM
RAM Installed (Max)
32 MB
Flash Memory
Flash Memory
6 MB
Media Handling
Media Type
Thermal paper
Media Size Class
A4
Max Media Size
216 x 5490 mm
105 mm x 25.4 mm
216 mm x 5490 mm
Media Sizes
A4 (210 x 297 mm)
Media Feeders
1 x manual - 1 sheet - 216 x 5490 mm
Print server
1 x USB 2.0 - 4 pin mini-USB Type B
Head cleaner
1 x USB cable
MFI
Limited warranty - 3 years
25.5 cm
5.5 cm
3 cm
480 g
Type: Printer
Wireless Capability: Wireless
Max Print Speed: 8ppm
Max Paper Size: 216 x 5490 mm
Brand: Brother
Price Range Ex VAT: 500 - 750
