Brother PJ-722 A4 Thermal Mobile Printer
Quicklinx: C352WS00 Mfr#: PJ722Z1
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Technology: Thermal Ink-jet
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
  • Windows 8 (32/64 bits)
Hurry, only 2 left in stock!
£366.26 ex VAT
£439.51 inc VAT
This rugged and durable "in the field" printer is an ideal printing solution for sales/service, logistics/delivery and public safety/emergency officials. The USB connection conveniently links to your PC's and laptops. It offers a fully portable and lightweight printing solution that's not much wider than an A4 sheet of paper, making it ideal for carrying in a bag or being mounted in a vehicle or a specialist case, as part of a complete mobile solution. The PJ-722 can print at up to 8 pages per minute, at a resolution of 203x200dpi on either cut-sheets, or continuous rolls that can be easily torn off. Support for up to A4 sized paper makes it ideal for invoices, service reports and delivery reports. A wide range of accessories are available to customise your mobile print solution to your requirements.
High quality A4 printing on the move
The Brother PJ range of mobile printers finally offer businesses a reliable way of producing high quality A4 sized prints wherever and whenever they are required. Featuring direct thermal printing, this technology is considered by many to be the only reliable solution for mobile print applications. And as no ink, toner or ribbons are used, this ensures workers don't have to source expensive replacements when they run out - the only consumable used is the paper itself.
Compact and lightweight
Despite its incredibly small size and lightweight design, the development and manufacturing process has been focussed on producing a durable, professional printer that can be carried in a briefcase or computer bag, or permanently mounted in a vehicle.
Integrate printing within your existing mobile apps and software
Enabling printing within existing apps or software used to be a difficult task. However, as well as standard printer drivers for Windows®, Mac and Linux, Brother has a range of SDK (Software Development Kits) that allow developers to easily add printing capabilities into existing solutions, or allow new printing apps to be developed quickly and efficiently. SDK's are available for iOS, Android and Windows® operating systems.
B connectivity
Offering the reliability of a wired connection, you can connect to Windows®, Mac or Linux based desktops and laptops, or to Android devices that have USB Host support (requires Android OS ver 3.1 or later).
Brother PocketJet PJ-722 - printer - monochrome - direct thermal
Printer Type
Personal printer - direct thermal - monochrome
Portable
480 g
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm
Print Speed
Up to 8 ppm - B/W
Max Resolution (B&W)
203 x 200 dpi
USB 2.0
RAM Installed (Max)
32 MB
Flash Memory Installed (Max)
6 MB
Language Simulation
EPSON ESC/P, EPSON ESC/P Raster
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, MicroPDF417, Code 128, Postnet, PDF417, Data Matrix, ITF, Micro QR code, EAN-8, EAN-13, MSI, GS1-128
Media Type
Thermal paper
Lithium Ion
Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Apple MacOS X 10.10.x, Windows 10 (32/64 bits), Apple MacOS X 10.11.x
Microsoft Certification
Compatible with Windows 7
3-year warranty
25.5 cm x 5.5 cm x 3 cm
Printer Type
Printer
Print Speed
Up to 8 ppm - B/W
Wired
USB 2.0
203 x 200 dpi
Language Simulation
Barcodes
RAM
RAM Installed (Max)
32 MB
Flash Memory
Flash Memory
6 MB
Media Handling
Media Type
Thermal paper
Media Size Class
A4/Legal
Max Media Size
216 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm)
Media Feeders
1 x manual - 1 sheet - Legal (216 x 356 mm)
1 x USB 2.0 - 4 pin mini-USB Type B
Head cleaner
1 x USB cable
Lithium Ion
Run Time (Up To)
600 pages
Limited warranty - 3 years
-10 °C
50 °C
20 - 80% (non-condensing)
25.5 cm
5.5 cm
3 cm
480 g
Type: Printer
Brand: Brother
Price Range Ex VAT: 300 - 500
