Brother PDS-5000 A4 Document Scanner
Quicklinx: BJ72WS00 Mfr#: PDS5000Z1
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 218 x 5994 mm
Interface: USB 3.0
Compatibility: Mac, PC
£570.05 ex VAT
£684.06 inc VAT
At up to 120ipm (images per minute) 2-sided scanning and supported by a 100 sheet ADF (Automatic Document Feeder), the PDS-5000 is capable of handling high scan volumes for businesses digitally converting on a regular basis.
Expert paper handling with the Ultrasonic Multifeed Detection and Reverse Roller technology reduces the risk of damaged documents, offering outstanding reliability when batch scanning a variety of document types and weights. The PDS models can handle a range of media capacities up to embossed plastic card, addressing all user and departmental needs.
As well as paper handling upgrades, PDS-5000 has enhanced image processing. Advanced image processing features prepare and clean scanned documents, improving the quality of the scanned image for storing, editing and sharing. Business critical documents retain their original appearance, giving businesses a professional edge when printing or viewing scans with customers, or when storing for disaster recovery.
Brother PDS-5000 - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Scanning Sensor Type
Dual CCD
Additional Functions
Email, scan to print, scan to network share, scan to cloud, scan to FTP, scan to file
Max Supported Document Size
218 x 5994 mm
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 24-bit (16.7 million colours), 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
218 mm x 5994 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
6000 scans per day
Red Hat Linux 9, Microsoft Windows XP, Debian Linux, Microsoft Windows 7, Microsoft Windows Vista, Ubuntu 6.06, Mandriva Linux, openSUSE, Windows 8, Apple MacOS X 10.8.x, Apple MacOS X 10.9.x, Apple MacOS X 10.10.x
31.6 cm x 18.7 cm x 18.3 cm
4.7 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 3.0
218 x 5994 mm
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Dual CCD
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
60 ppm - black & white - A4 - 300 dpi , 60 ppm - colour - A4 - 300 dpi , 120 ipm - duplex - black & white - A4 - 300 dpi , 120 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
Paper Protection Function, Page length detection, Blank Page Removal, Barcode Detection, automatic colour detection, Punch Hole Removal, Image Rotation, 2 line x 16 character LCD, Edge Enhancement, Continuous Scanning
TWAIN, ISIS, WIA
Media Handling
Max Document Size
218 mm x 5994 mm
Supported Document Size Details
ADF - up to 218 x 5994 mm
Automatic
100 sheets
USB 3.0
Carrier sheet
1 x SuperSpeed USB cable
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
59 Watt
Power Consumption Stand by
19 Watt
Software Included
Drivers & Utilities, QuickScan Pro (Trial), Avision Button Manager 2, Presto! PageManager 9 for Mac, DSmobileCapture, Nuance OmniPage 18 SE
31.6 cm
18.7 cm
18.3 cm
4.7 kg
Shipping Width
43.7 cm
Shipping Depth
29.6 cm
Shipping Height
32 cm
Shipping Weight
7.2 kg
Sound Emission
55 dBA
Interface: USB 3.0
Compatibility: Mac
Compatibility: PC
Brand: Brother
Price Range Ex VAT: 500 - 750
