Designed for use in almost any retail work space, the TD-2020 is among the most compact and fastest 2.2-inch wide desktop thermal printers for retail applications. At 203dpi, it prints price, mark-down, product identification, returns and shelf-edge labels quickly at up to 6ips. Also prints tags and receipts for kiosk and POS applications. An innovative drop-in roll, spindle-less design helps make loading easy with existing or standard converted media.
Small size, but big on performance
Although these printers are among the smallest desktop thermal printers in their class, they also lead in performance over many 203 dpi print resolution desktop thermal printers. -
Ergonomic design
Uses an innovative spindle-less design that accepts labels, tags or receipt media with virtually any core size for a true drop-in media roll loading experience on a desktop, cart or even mounted to a wall. -
Adjustable edge-to-edge media sensor
Flexibility to detect and print on more types of existing thermal media to help avoid converting custom media. -
Print from a database
Helps save time and increase accuracy by printing labels, tags and receipts linked directly to Microsoft SQL Server, Access or Excel database files.
- Brother TD-2020 - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.34 kg
- Max Media Size
- Roll (6.3 cm)
- Min Media Size (Custom)
- 19 mm
- Max Media Size (Custom)
- 63 mm
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB 2.0, serial, USB host
- RAM Installed (Max)
- 6 MB
- Language Simulation
- EPSON ESC/P, ZPL II, EPSON ESC/P Raster
- Barcodes
- Code 93, Code 39, UCC/EAN-128, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, PDF417, Data Matrix, ITF, Truncated PDF417, Micro QR code
- Media Type
- Receipt paper, paper tag, die cut labels, wristband labels
- Compatible Tapes
- RD tape
- Fonts
- Brussels, Helsinki, San Diego, Letter Gothic Bold
- Styles & Effects
- Bold, Mirror
- Black Mark sensor, gap sensor
- Networking
- Print server
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
- 3-year warranty
- 11.1 cm x 21.5 cm x 17.2 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Connectivity Technology
- Wired
- Interface
- 203 dpi
- Fonts
- Styles & Effects
- Bold, Mirror
- Auto Cutter
- Barcodes
RAM
- 6 MB
Media Handling
- Media Type
- Compatible Tapes
- RD tape
- Max Media Size
- Roll (6.3 cm)
- 19 mm
- 63 mm
- Media Sizes
- Roll (6.3 cm)
- Max Printing Width
- 56 mm
- Max Printing Length
- 1 m
- Media Thickness Range
- 0.058 mm - 0.279 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm
- Networking
- Print server
- Connections
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB cable
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- Software Included
- Driver
- OS Required
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
- 11.1 cm
- 21.5 cm
- 17.2 cm
- 1.34 kg
