Professional label printing for the modern home and office
The P-touch P750W is an advanced yet easy-to-use Wi-Fi enabled labelling machine that everyone in your organisation can use to quickly design and print labels up to 24mm in width. Label file folders, archive documents, data backup discs/USB sticks and shelves, or create custom signage. P-touch Editor 5 software lets you use your PC's fonts, and include images, symbols and barcodes on your labels, or download the iPrint&Label app to design and print labels from your smartphone or tablet.
Key Features
- Fast print speeds of up to 30mm/sec (when used with AC adapter)
- Use as a portable device with optional Li-ion battery
- Print labels 3.5 to 24mm in width.
- Built-in Wi-Fi to share around the office.
- Automatic cutter with half-cut option for easy-to-peel labels and reduced wastage.
- Choose from any of your installed true type fonts.
- Add a logo, symbol or frame to your labels.
- Free iPrint&Label design app for your iOS and Android smartphone/tablet.
- NFC reader to easily connect your NFC enabled mobile device.
Extra Features
- Use as portable device, with optional li-ion battery.
- Share label printing between many users.
- Built-in auto cutter with full/half cut feature.
- Includes tape cassette, AC adapter, USB cable.
- Prints 3.5, 6, 9, 12, 18 and 24mm labels
P-touch laminated labels - designed to last
Brother P-touch laminated TZe tapes consist of six layers of materials, resulting in a thin yet extremely strong label. The thermal transfer ink is sandwiched between two protective layers of PET(polyester film), which protects the text against the effects of liquids, abrasion, temperature, chemicals and sunlight. As the labels have been tested to the extreme, you can be confident of a professional quality label that has been designed to last.
Clearly identify items with a durable P-touch label
Around the home, office, school, shop and other places of work, there are many uses for long lasting, durable P-touch labels. Common examples include:
- Cables and plugs
- CDs and DVDs
- Office equipment
- File folders
- Staff and visitor name badges
- Filing cabinets
- Signage
- Mail rooms
- Notice boards
- Shelving
- Telephone extension numbers
- Brother P-Touch PT-P750W - label printer - B/W - thermal transfer
- Printer Type
- Label printer - thermal transfer - B/W
- 800 g
- Max Media Size
- Roll (2.4 cm)
- Max Media Size (Custom)
- 24 mm
- Print Speed
- Up to 30 mm/sec
- Cutter
- Interface
- USB 2.0, Wi-Fi(n), NFC
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
- 7.8 cm x 15.2 cm x 14.3 cm
- Printer Type
- Label printer - thermal transfer - monochrome
Printer
- Print Speed
- Up to 30 mm/sec
- Interface
- Cutter
- Repeating Printing
- 5000 copies
Media Handling
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Max Media Size
- Roll (2.4 cm)
- 24 mm
- Media Sizes
- Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
- Max Printing Width
- 18.1 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (2.4 cm)
- Connections
- 1 x USB 2.0
- Cables Included
- 2 x USB cable
- Media Included
- 1 24 mm x 4 m black on white TZe tape cassette
- Power Device
- Power adapter - external
- OS Required
- 7.8 cm
- 15.2 cm
- 14.3 cm
- 800 g
